Can flat iron be heated by friction?
The discussion revolves around the feasibility of heating a flat iron using friction as an alternative to conventional energy sources such as electricity, fuel, or solar power. Participants explore the mechanics and practicality of generating sufficient heat through friction.
  • Participants question how to generate enough friction to produce the necessary heat, with some expressing skepticism about the effectiveness of rubbing the iron on fabric. Others suggest alternative methods, such as using horseshoe magnets for eddy current heating.
The conversation is ongoing, with various ideas being proposed, including the potential use of flywheels for energy storage. There is no clear consensus, but several participants are actively engaging with the problem and offering different perspectives.
Some participants note constraints related to the definition of energy sources, particularly regarding the exclusion of electricity and solar panels. Additionally, there are discussions about the efficiency of human power in generating heat through friction.
Erish
< Mentor Note -- thread moved to HH from the technical engineering forums, so no HH Template is shown >[/color]
Hi! We are looking for alternative ways to heat up flat iron without using electricty or fuel or solar panel. So we came up with friction (as it is also a source of heat). But we don't know if it will work. So if you can help us please gave us some ideas about this. Thank you very much!
Sure it will work but how are you going to produce the motion to cause the friction to produce the heat?
That's our problem! we don't know how to produce so much friction to generate the heat needed. we think that rubbing the iron on the clothes will not be enough to produce the heat. :(
The other nasty thing about friction is it tends to destroy things...
If you are looking at this as a way to save energy, unless you have a ready and untapped source of friction, you wont; both friction and electricits have exactly the same efficiency in conversion to heat (100%).
So you want to iron something and produce the heat by hand necessary to adequately press the cloth. I could not find a coefficient of friction for a fabric on steel but assuming a nominal value of .0.3 , an iron wgt of 5 lbs., a stroke of 1 ft, a temperature increase of 200 deg F, a specific heat of iron of 0.11 BTU/deg F*lb and assuming little heat is lost by the iron in the process you can determine the number strokes you need to accomplish this feat.
If you had a bunch of horseshoe magnets and could rub them madly around the surface of the steel I think heat would be produced within the steel. The process is known as eddy current heating. It probably qualifies as using no electricity, in the same way as your food-powered human generating friction heating is categorised as a process not burning fuel. :smile:
How much heating power could one human produce? For best case data I'd look at bicycle experiments, since peddling harnesses our biggest most efficient muscles.
Info here relates to a steam iron but..
http://www.infomania.co.uk/archives/36
It suggests the 1700W element was on for roughly half the time the iron was in use. So the average was around 850W or 1.1 HP. That's more power than an average human could sustain...
https://en.wikipedia.org/wiki/Human_power
A trained cyclist can produce about 400 watts of mechanical power for an hour or more, but adults of good average fitness average between 50 and 150 watts for an hour of vigorous exercise.
That is a huge understatement. The most elite bicyclist in the world would have difficulty sustaining this level of output for more than a few minutes (search bicycle toaster and watch the video). It would take half a dozen or more "average adults" to do it.
BoB
We don't want an idea to be necessarily stymied by ambition. An iron that looked like something belonging to a doll's set would suffice as a proof of concept demonstration, I'm sure. [emoji1338]
Ok, perhaps you could store the energy in a flywheel or battery?
Just returned to amend my post to suggest a flywheel. A storage battery would be excluded by the no electricity restriction.
Pressure instead of heat .
Heavy iron .
Two boards with weights on top .
Old type trouser press with screw clamps .
Big lens or array of mirrors or would that come under "solar panel"?
Geothermal. Go and set up camp by a lava flow or hot spring :smile:.
[sorry, didn't read the title... and on second thoughts a fire might be easier anyway.]
  • · Replies 17 ·
