Can Fleming's Right Hand Rule Be Used When Magnet Moves Parallel to Coil?
  • Context: High School
  • Thread starter Thread starter GeneralOJB
    hand Right hand rule
The discussion centers on the applicability of Fleming's right hand rule in determining the direction of current when a magnet is moved in relation to a coil of wire, particularly when the magnetic field and movement are parallel. Participants explore the conditions under which the rule can be applied and the implications of different orientations of the magnetic field.
  • One participant questions whether Fleming's right hand rule can be used when the magnetic field and movement are parallel, suggesting that it may only apply when the wire moves in a magnetic field at right angles.
  • Another participant challenges the assertion that the magnetic field and movement are parallel, indicating confusion about the orientation of the magnetic field.
  • Some participants discuss the direction of the magnetic field, clarifying that it extends from the north to the south pole of the magnet.
  • A participant proposes using the right hand generator rule instead and describes a scenario where the solenoid moves while the magnet is stationary, detailing how to apply the rule to determine the direction of induced emf.
  • There is mention of Lenz's law as a method to determine the direction of induced current, suggesting that the current will oppose the motion of the magnet.
  • One participant expresses uncertainty about the implications of infinite magnetic field lines and seeks clarification on using the left hand rule in this context.
Participants do not reach a consensus on whether Fleming's right hand rule can be applied in the discussed scenario. There are competing views regarding the orientation of the magnetic field and the appropriate rules to use for determining current direction.
Participants express confusion regarding the definitions and orientations of magnetic fields, as well as the application of different rules (right hand vs. left hand) in this context. The discussion highlights the complexity of the scenario without resolving the underlying assumptions.
GeneralOJB
Can I use Fleming's right hand rule to determine the direction of current when a magnet is moved into a coil(s) of wire? I am finding it difficult because the magnetic field and movement are parallel instead of at right angles.
If not, does this mean I am only allowed to use it when a wire moves in a magnetic field (at right angles)?
Are you sure they are parallel? I don't think so.
This is what is confusing me then.
Consider a set-up like this:
The magnet field points up (north to south) and the movement is also vertical, so the field and movement are parallel.
Where is the south? Down? Magnetic field is from North to south.
The south is on the other end of the magnet, above the north.
bar-magnet-magnetic-field.jpe
Is the field parallel to the bar?
Yes (I presume so).
Do you see why it's not parallel now?
I was told that the field is from north to south, so is that not really true then? It seems the field is both perpendicular and parallel from that diagram. Also how can I use the left hand rule to determine the direction of current in this case if the field is going in infinitely many different directions perpendicular to the movement?
GeneralOJB said:
how can I use the left hand rule to determine the direction of current in this case ?
I wanted an answer to this problem too but I didn't really understand what my teacher told me.
The problems with infinite field lines seems far too advanced to me. May a more experienced member help thou and myself.
dauto!
(1) It's the right hand generator rule that you need. (2) Suppose the magnet to be stationary and the solenoid moving up the page in the diagram in post 8. (3) Now concentrate on just one small section of wire in the solenoid; let's choose the piece in the top front of the coil. (4) Observe that in the region of this section of wire the magnet's magnetic field is more or less coming out of the page towards you. (5) So point first finger of right hand out of the page and thumb up the page (the way the wire is moving. (6) Then your second finger will point in the direction of the induced emf. You should find that this is roughly from left to right - if you haven't dislocated any joints. (7) You'll find the same result: emf anticlockwise (looking from above) around the solenoid whichever section of wire you choose.
There's a much nicer way of finding the direction of the induced emf in cases like this: use Lenz's law… The current that will flow as a result of the emf if we short-circuit the coil (join its ends together) will produce a magnetic field which will oppose the coming together of the magnet and the solenoid. So the top end of the solenoid will become a North pole, that is flux lines will come upwards out of it. Using the right hand grip rule, we can deduce that the current, and hence the emf, in the coil is anticlockwise (seen from above).
It would be nice if you say whether this is of any help...
  • · Replies 32 ·
  • · Replies 16 ·
  • · Replies 40 ·
