Can Fluent 6.3.26 be used to analyze flow rate and heat in a copper tube?
The discussion revolves around the use of Fluent 6.3.26 to analyze the flow of oil through a hollow copper tube subjected to heat. Participants explore the thermal and stress characteristics of the system, particularly focusing on how heat transfer affects the oil and the stress points in the tubing under varying flow rates.
  • One participant inquires whether Fluent 6.3.26 can be used for analyzing the flow and heat transfer in a copper tube.
  • Another participant suggests that while Fluent can analyze the problem, simpler calculations could suffice for determining stress and outlet temperature of the oil.
  • There is a discussion about the heat transfer from the copper tubing to the oil, with a formula provided for calculating the exit temperature based on mass flow rate and specific heat.
  • Concerns are raised about the stress in the tubing, particularly how it relates to pressure and the geometry of the tubing, including potential complications at bends.
  • Participants discuss the configuration of the tubing, with one describing it as a double pipe serpentine coil and noting the effects of overlapping coils on heat transfer.
  • Specific calculations for hoop stress are proposed, contingent on the dimensions and material properties of the tubing.
  • Questions are posed regarding the operating pressures and specific heat of the mineral oil used in the system.
Participants generally agree that Fluent can be used for the analysis, but there is no consensus on whether it is necessary given the availability of simpler calculations. Multiple views on the approach to calculating stress and heat transfer remain, with ongoing questions about specific parameters and conditions.
Participants express uncertainty regarding the operating pressures of the tubes and the specific heat of the mineral oil, which may affect the calculations. The discussion also highlights the complexity introduced by the geometry of the tubing and the interaction between overlapping coils.
This discussion may be useful for individuals interested in fluid dynamics, heat transfer analysis, and mechanical stress calculations in engineering applications, particularly those involving thermal systems and tubing configurations.
origen87
hello all,
i am from electrical background and for a project i need to analyse the flow of oil through a hollow copper tube when the tube is subjected to some amount of heat. the outcome should tell me if the heat will be absorbed by the oil and what would be the stress points when i apply different amount of fluid flow rate. can fluent 6.3.26 be used for this?.if so please let me know how to start, because its totally new to me..
thanks a tonne:)
I am sure Fluent can analyze this problem for you but you don't need to go to that level of detail to determine the stress and outlet temperature of the oil.
... if the heat will be absorbed by the oil
The heat has to go somewhere, so yes the amount of heat not absorbed by the copper tubing will be absorbed by the oil and this will increase the temperature of the oil when it exits the copper tubing.
To calculate the exit temperature simple use the following formula
q = mCpdt
where
m = mass flow rate of the oil (lbs/hr)
Cp = specific heat of the oil at constant pressure (Btu/lb-F)
dt = temperature difference between the inlet and outlet of the oil
q = heat absorbed by the oil (Btu/hr)
Use this equation to perform a heat balance between the oil and the fluid that is doing the heating.
... stress points ...
The stress in the tubing is dependent upon the pressure. So for a constant diameter tubing increasing the pressure will increase the stress in the tube wall. See the ASME (American Society of Mechanical Engineers) Section VIII Div.1 for a standard wall thickness calculation for the tubing. If you don't have access to it, let me know and I can help you out.
If you have turns in the tubing the stress at the elbows is not a straight forward calculation.
I am assuming that you are trying to design a hot oil heater with multiple passes using 180 degree return bends. Am I correct?
Trust me, if you haven't used Fluent before, you will spend more time trying to figure out how to use Fluent then you will doing these simple hand calcs and once you are done you will see the Fluent results are probably within .1% of your simple hand calcs.
Thanks
Matt
Thanks Matt!
Well these are coils(round, similar to a suspension used in automobiles) one overlapping the other, I am through with the temp calculations but for presenting it to my boss I need to have a model which is simulated and shows the heat at tube at different points and corresponding stress. When such coils are overlapped the heat of one tube will have effect on others too.
So you have a double pipe serpentine coil?
Are you able to show a picture or print of it?
Thanks
Matt
k..i wil sketch a rough figure.
Hey Matt,
very rough sketch though,but will give you an idea of the system, the two coils are separated by some kind of insulation.
Thanks for the print.
Well, the equation in my first reply is still valid for this system.
If you want to calculate a heat flux, you can "unwrap" the coil and calculate an equivalent straight length of tubing and use that in the heat flux calculation. The only problem there would be with calculating an accurate inside and outside convection coefficient. What is the fluid you are using for heating?
What quantities do you want to calculate?
Thanks
Matt
I am using mineral oil..the one used in transformers..i need to find out the stress at every point.
... need to find out the stress at every point.
Is the outer tubing the same diameter from the beginning to the end? If so the calculation for it is simple.
Sh = (p*r)/t
where
Sh = hoop stress (psi)
p = internal pressure (psi)
r = inner radius (inches)
t = tube thickness (inches)
This will be the stress at every location in the outer tube of the serpentine coil
If you specify and allowable stress for the tube material, you can use the above formula to calculate the required minimum tube thickness.
The inner tube is different because it is pressurized externally. See the ASME code Section VIII Div.1 for the procedure for this. If you don't have access to the ASME let me know.
Thanks
Matt
hey thanks matt!well i don't have access to that, could you please help me with that
What is the inner pressure of the inner tube?
What is the inner pressure of the outer tube?
What material is the tubing? UNS # ? ASTM Spec?
What is the inlet and outlet temperatures of the inner and outer tubing?
Thanks
Matt
I know the needed pressure difference, and that is 3.92 bar,velocity of flow being 0.7m/s.its electrolytic copper(99.9%pure).ASTM spec...inlet temp 80c and outlet 25c
hey sry,,,inlet is 25,,,n outlet is 80c
Oh yeah I forgot to ask you,
What are the inner diameters of both tubes?
Do you have the mean specific heat of the mineral oil?
Thanks
Matt
id=6.5mm,od=8.2mm,,,,,,,,id=4.9mm,od=5.5mm
1.67 kJ/kg.K
origen87, I am out of my office today. I will be able to help you tomorrow.
Thanks
Matt
I know the needed pressure difference,..
Could you get the actual operating pressures of the inner and outer tubes?
Thanks
Matt
i dnt have any clue of d operating pressures. initially i knew only required flow rate and tube dimensions that gave me the pressure difference reqd.
  • · Replies 131 ·
12K
