Could a Wormhole and Black Holes be Used to Reverse the Big Bang?
  • Thread starter Thread starter tribdog
The discussion explores the theoretical possibility of using wormholes and black holes to reverse the Big Bang by manipulating time and gravity. A concept is presented where a wormhole connects two points in time, allowing objects to emerge earlier, while introducing black holes could exponentially increase gravitational mass. Concerns about energy conservation are addressed, noting that mass remains constant across the wormhole's entrances. The implications of electric charge and mass changes at the wormhole mouths raise questions about stability and adherence to the positive energy theorem. Overall, the conversation highlights speculative physics and the potential for time manipulation through advanced theoretical constructs.
tribdog
say I make a wormhole, a big one. that instead of connecting two places in space it connects two places in time. something that goes in one end comes out the other 1 second earlier. Then I throw in a black hole. which goes back in time and comes out the other end and now i have two black holes which go in and now I have four then eight etc. can I now reverse the big bang with all my extra gravity?
Astronomy news on Phys.org
so I can't do it because Mr. Sawyer says so?
I'm not sure how well a wormhole will accommodate a black hole.
As far as the energy conservation issues go, the entracne wormhole mouth will gain all the mass of anything that passes through it, and the exit wormhole mouth will lose that mass. So the total mass at both ends of the wormhole remains constant.
Thus if black holes could pass through wormholes without any problems (I don't know the answer to this, as I mentioned), on the exit side you'd have a large negative mass wormhole mouth together with a bunch of smaller positive mass black holes, but the total mass on the exit side of the wormhole before and after the emergence of the black holes wouldn't change.
Note: this implicitly assumes that you have an isolated section of the universe to play with, one that has an asymptotically flat space-time, so that you can measure the mass.
See for instance
http://www.npl.washington.edu/av/altvw69.html
If a positive electric charge Q passes through a wormhole mouth, the electric lines of force radiating away from the charge must thread through the aperture of the wormhole. The net result is that the entrance wormhole mouth has lines of force radiating away from it, and the exit wormhole mouth has lines of force radiating toward it. In effect, the entrance mouth has now been given a positive electric charge Q, and the exit mouth acquires a corresponding negative charge -Q. Similarly, if a mass M passes through a wormhole mouth, the entrance mouth has its mass increased by M, and the exit mouth has its mass reduced by an amount -M.
Note that this creates some stability issues, as Cramer goes on to discuss. Also note that while this article appeared in a science fiction magazine, it is a factual (popular-level) article by a professional physicist who also writes science fiction.
Would the worm holes mouth not then violate the positive energy theorem?
I think physicists have postulated something like this for a long time. The basic mechanism would involve putting one "end" of a wormhole in a deep gravity well, such as very near a neutron star or black hole, where gravitational time dilation would pile up an offset between the two ends. When you get the right delay, then move the business end away from the neutron star/black hole, and you have an instant time--and space--machine
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
