Can I Use an Electromagnet to Repel Aluminum?
An electromagnet created with a microwave oven transformer and a 1.5 D cell battery is attracting ferrous metals but failing to repel aluminum, which is paramagnetic and typically shows slight attraction to magnetic fields. The discussion highlights that aluminum and other non-ferrous metals do not generate eddy currents in a direct current (DC) magnetic field, which is necessary for repulsion. To create eddy currents and achieve repulsion, switching to an alternating current (AC) power source is recommended, along with using a step-down transformer to manage voltage safely. Adjustments to the model, including adding a resistor in series, can help prevent overload. Understanding these principles is crucial for effectively using electromagnets with non-ferrous materials.
Yummy Yum
I have made an electromagnet using the primary core of a microwave oven transformer and a 1.5 D cell battery.
I would like to use the electromagnet to repel an aluminum bar (1 in. dia., 3 in. in length, and 1/4 in. thick; it is shown in the picture)
For some reason, the electromagnet only attracts to ferrous metals, but does not repel non ferrous metals (like the aluminum bar). According to my research, some non ferrous metals will not be repelled by electromagnets, but aluminum should definitely be repelled.
I've attached a picture of my electromagnet
I've done everything I can think of to try and make the electromagnet repel the aluminum bar. I've tried switching the wires from positive to negative and vise versa, changing the battery size, and changing the thrust direction.
What can I do to make my electromagnet repel this aluminum bar?
Thanks
Thanks
Aluminum is paramagnetic, so it has a slight attraction to magnetic fields.
But, shouldn't non ferrous metals like aluminum and copper be repelled due to Eddy currents?
You don 't get eddy currents with a dc magnetic field.
As for when you thrust, that force is probably too weak and of too short duration to move the metal.
Sorry, I'm kind of new to this. So, if I wanted to create eddy currents, how would I adjust my model to use an ac power source?
For safety's sake I suggest a step-down transformer 115V to maybe 26V (a common type), then you need a resistor in series with your coil to keep the current manageable. Idea is not to overload the transformer.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
