B Can Ionic Compounds conduct electricity in a gaseous state?
  • B
  • Thread starter Thread starter SliverStrike
Metallic substances can conduct electricity in both solid and liquid forms due to their valence electrons. Ionic substances conduct electricity only in liquid form through ion movement, not as solids. Molecular substances do not conduct electricity in either state. Gases generally do not conduct electricity unless ionized into plasma, which allows for free movement of electrons and ions. The discussion also touches on solid-state ionics, where ionic substances can conduct electricity in solid form under specific conditions.
SliverStrike
TL;DR Summary
Can electrolysis be performed on an ionic compound in a gaseous state??
A metallic substance in solid or liquid form can conduct electricity because of its valence electrons.
An ionic substance in liquid form can conduct electricity through the movement of the ions but not as a solid.
A molecular substance cannot conduct electricity in solid nor liquid form.
In case you're wondering, these information are from a chemistry textbook but there is no mention of these substances in gas form. Would the gas form of any of the three substances conduct electricity if so which ones?
Welcome to PF.
Welcome to PF.
A cold gas will not conduct electricity. Sufficient energy to ionise the gas must be provided, making it a plasma, before electrons and ions will be free to move separately.
So if we supply sufficient energy to ionise a gas of an ionic compound would it break down into its constituent parts as in electrolysis once cooled down or reform?
This statement is not quite correct as ionic substances in solid form can conduct electricity through the movement of ions. This is the realm of solid-state ionics: The study of ionic-electronic mixed conductors and fully ionic conductors (solid electrolytes) and their uses.
https://en.wikipedia.org/wiki/Solid_state_ionics
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
