Can longwave radiation heat the oceans?
  • Thread starter Thread starter Loudzoo
    Heat Radiation
The discussion centers on whether longwave radiation, specifically infrared (IR) radiation, can effectively heat the oceans. Participants explore the mechanisms of heat transfer, the role of evaporation, and the implications of atmospheric back radiation on ocean temperatures. The conversation includes theoretical considerations and challenges related to experimental observations.
  • Some participants question whether IR radiation can penetrate the ocean and effectively contribute to heating, suggesting it primarily causes evaporation at the surface.
  • Others propose that while IR does heat water, the rate is low and insufficient to significantly increase ocean temperatures compared to shortwave radiation.
  • A participant mentions that heat conduction from the warm surface to cooler layers below may play a role in temperature distribution.
  • Concerns are raised about the limitations of using simple experiments to model ocean heating, particularly regarding evaporation rates and heat conduction through materials.
  • Some argue that increased atmospheric back radiation could lead to higher ocean temperatures by altering the IR flux at the surface, while others counter that this energy primarily contributes to evaporation rather than heating the bulk ocean.
  • Discussions include references to scientific literature and data, questioning the validity of claims made by various sources regarding IR absorption and its effects on ocean temperature.
Participants express differing views on the effectiveness of IR radiation in heating the oceans, with no consensus reached. Some agree that IR contributes to surface heating but debate its overall impact on deeper ocean temperatures, while others challenge the assumptions underlying these claims.
Participants highlight the complexity of measuring the effects of IR radiation on ocean temperatures, noting the challenges of isolating variables such as evaporation and heat conduction. The discussion also reflects varying interpretations of scientific data and models related to radiation absorption in water.
This discussion may be of interest to those studying climatology, oceanography, or the effects of greenhouse gases on climate systems, as well as individuals curious about the interactions between radiation and oceanic processes.
Loudzoo
Thats my simple question!
Is there some reason it shouldn't?
Hi bystander - I read that infra red could not penetrate the ocean but caused evaporation on the surface skin. If that is true then infra red would not be able to heat the ocean like short wave radiation does. Is that true? thanks
The enthalpy of vaporization has to come from somewhere --- you don't suppose IR absorption by water might be the source?
Absolutely is the source in this example. But the energy from the incoming IR is not retained by the ocean as heat - its released through evaporation into the atmosphere. So is it correct to think that IR cannot heat (i.e. increase the temperature) of the ocean?
No. IR does heat water but at a very low rate, with not much energy compared to temperature coefficient of water.
Consider also, conduction of heat from the "warm" surface to cooler water layer below the surface. To quote a faculty member from grad school days, "Every calorie looks the same once it's off the bus." Assigning origins and destinations to energies can be misleading.
Thanks Doug. The IPCC estimates that a doubling of CO2 in the atmosphere would increase radiative forcing by 3.7W/m2 assuming clear sky conditions. This could only heat water in the top few molecules initially if water is as impermeable to infra red as I understand. Then as Bystander says any heating at the surface which does not evaporate surface skin molecules could be conducted to (or just mixed with) deeper levels. Could you point me in the direction of calculations as to what the magnitude of this heating might be? I completely understand that measuring this through real world observations must be very difficult as the calories are off the bus by then, but someone must have modeled this or tested this in a controlled environment?
The IPCC spins at best and lies at worst. Impeached.
Quick and dirty demonstration? Two liter soda bottle filled with water; measure T in the morning; leave in sun all day; measure T in late afternoon.
But sunlight is Short wave radiation ! Bystander - the experiment you suggest would only tell me what I already know that: short wave radiation heats water. I want to understand if infra red can heat water!
Bystander - I found the following passage on a CAGW skeptic's website (http://climaterealists.com/index.php?id=4245)
"However the effect of downwelling infrared is always to use up all the infrared in increasing the temperature of the ocean surface molecules whilst leaving nothing in reserve to provide the extra energy required (the latent heat of evaporation) when the change of state occurs from water to vapour. That extra energy requirement is taken from the medium (water or air) in which it is most readily available. If the water is warmer then most will come from the water. If the air is warmer then most will come from the air. However over the Earth as a whole the water is nearly always warmer than the air (due to solar input) so inevitably the average global energy flow is from oceans to air via that latent heat of evaporation in the air and the energy needed is taken from the water. This leads to a thin (1mm deep) layer of cooler water over the oceans worldwide and below the evaporative region that is some 0.3C cooler than the ocean bulk below."
The last sentence does seem to be validated with this paper: http://www.nature.com/nature/journal/v358/n6389/abs/358738a0.html
But is the rest fair?
Doug - I'm not sure I'm reading your graph correctly but it does seem to show that sunlight at sea level is a mixture of UV, visible and infra red wavelengths. If so - putting a bottle of water in the sunlight and measuring the temp change over a day isn't going to tell me anything about the effectiveness of IR in heating water
The shortwave (visible) is going right on through. That's observation one. A day in the sun will bring the bottle up to 60-70 C. That's observation two. From the Planck radiation law 75% of the energy in sunlight is transmitted at wavelengths longer than the peak intensity wavelength, 500 nm (red).
Dear Bystander - I appreciate your patience with me on this and I am grateful. That said, a bottle in the sunlight "experiment" is a blind alley if we're trying to understand the oceans. Low evaporation rates, the conduction of heat through the plastic of the bottle and diffraction of the light through the curved surfaces of the bottle all make such an experiment an extremely poor way to model the ocean temperature / IR relationship. Furthermore your comment on Planck radiation law calculations does not address this question if incoming IR causes evaporation in the ocean skin layer rather than an increase in the temperature of the ocean.
To get back on track do you agree that this graph is representative of the absorption spectrum of liquid water?
http://en.wikipedia.org/wiki/Electr.../File:Absorption_spectrum_of_liquid_water.png
If so - its clear that IR does not penetrate below 1cm and the wavelengths of back radiation from the atmosphere penetrate much less than that (e.g. 1/10^5 metres).
As per the nature article I referenced above (http://www.nature.com/nature/journal/v358/n6389/abs/358738a0.html) the top 1mm of the ocean is typically 0.3C cooler than the bulk mixed layer. Forgive me for being slow - but if most of the total IR radiation and all of the back radiation from the atmosphere penetrates less than the depth of the ocean skin layer that is cooler than the water below - how can IR increase the temperature of the ocean?
These observations suggest to me that almost all of IR radiation incident on the ocean causes evaporation rather than an increase in temperature of the ocean. Where am I going wrong?
Loudzoo said:
Where am I going
... not "wrong," into a "semantic ditch," perhaps. If you're going to give me all the solar radiation that penetrates further than 1 mm by the Kebes plot (shorter than 2 μm), you've given me 80 - 90% of the IR. If you define IR as only that radiation that is absorbed in 1 mm or less, and ignore the 0.8 - 2 μm gap between visible and IR acknowledged by a specific argument, you're losing a lot of energy.
Thanks Bystander. I think I get where you're coming from. I'll give you whatever IR you want! Thanks to this discussion I think I can now refine my original question a little more clearly:
Can an increase in Atmospheric back radiation (from say increases in atmospheric concentrations of greenhouse gases) lead to increases in ocean temperatures?
For anyone else that is interested in this topic I found this set of articles (and associated comments) really useful.
As with most other discussions in climatology the answer isn't simple . . .
What is "back radiation?"
its downward longwave radiation. IR radiating from the atmosphere down to the surface of the earth. Not IR direct from the sun.
Heat moves from (hotter/same T/cooler) body/system to (hotter/same T/cooler) body/system?
Heat moves from hot to cold obviously.
To summarise (and no doubt over-generalise!) one side of the argument seems to posit that:
solar radiation heats the ocean, but atmospheric radiation only heats the top few molecules. So increased Downward Longwave Radiation (DLR) is unable to transfer any additional heat into the bulk of the ocean, instead the energy goes into evaporating the skin layer into water vapor.
The other side of the argument seems to postulate that:
additional downward longwave radiation must alter the IR flux at the surface of the ocean leading to more IR being trapped in lower ocean layers and maintaining a higher water temperature than would be the case with less downward longwave radiation
so the downward longwave radiation doesn't heat the ocean but it slows the cooling that would happen with less DLR
And quite frankly I'm confused! What do you think?
I should also add that I'm very much aware that none of the stuff I've read on this is in the peer reviewed literature. Wozniak et al (2013) "Light abosrbtion in sea water" looks like it might be just what I need - but its paywalled . . . any other suggestions would be gratefully received
Not being "flip" with you --- just wanted to be sure we're both working from the same initial set of ideas/postulates/principles.
Welcome to the wonderful world of energy "balances" in non-equilibrium systems. The system we're "analyzing" (hah!) has as heat sources the sun, ~ 10-4steradians at ~ 5800 K or 1-1.3 kW/m2 at Earth surface, and crustal heat leak of 10-30 mW/m2, negligible. The heat sink is 4π steradians at ~ 4 K, the CMB. What else do we know? Some fraction of incident solar radiation is reflected, what fraction is subject to some uncertainty; some fraction is transmitted, very small through the atmospheric "halo", but enough to illuminate an otherwise totally eclipsed moon; and, some fraction is absorbed by atmo-, hydro-, and lithospheres, exchanged by conduction, convection, and radiation, and radiated to the CMB.
What are the exchange rates for each mechanism among the spheres? How good are the models? How good are the measurements? How do we know which "bus" which calorie came in on?
Thanks Bystander that makes me feel better but I can't help feel disappointed that certain reputable scientists describe the science as settled. It seems then that comments within CAGW community that the recent plateau / pause / hiatus in global mean atmospheric temperatures might be explained by the "missing heat" being "trapped" in the deep oceans is not a scientific conclusion from research but merely a hypothesis. Furthermore it seems proving that rising atmospheric CO2 concentrations can heat the ocean is also very difficult. It remains only a hypothesis.
I read that (as well as the other policy posts) before I started posting - and I hear you. I have no agenda other than to understand the physics. I don't know who is right and who is wrong and I don't have any pet theories of my own. As a human being I'd love to think CAGW is bunk because otherwise we're in serious danger. As someone who respects the truth and power of science and scientists I'd love to think its true because of the overwhelming scientific consensus. I understand the popular theory well enough but I don't understand the physical process of how additional CO2 in the atmosphere can lead to higher ocean temperatures. Can you help me? Many thanks again for your time and patience.
We can tip-toe through the argument/theory as you and I "understand" it, and as I think it's intended to explain things. So long as questions/doubts are based on established physical principles and we confine ourselves to resolving such questions/doubts within those principles, there shouldn't be any complaints.
That would be extremely helpful and if at any point there are suitable publications that I can go and read rather than have you waste time - please direct me accordingly.
If I may be so bold as to start.
CO2 is a "greenhouse gas" because it is an efficient absorber and emitter of various wavelengths of IR radiation. Without greenhouse gases in the atmosphere the Earth's atmosphere would be some 33C cooler on average. Approx 3C of that can be attributed to CO2 at current concentrations. Because the effectiveness of CO2 is logarithmic each doubling of CO2 atmospheric concentration leads to approx 1C increase in global mean atmospheric temperature. IPCC estimates in AR5 of 1.5C to 4.5C per doubling rely on positive feedbacks from water vapour in the atmosphere. The wide range is because we don't understand how positive the net feedback process is. As a generalisation of the popular theory does that sound about right?
An increase in CO2 atmospheric concentrations will increase IR radiation in the atmosphere and as a result will increase downward IR radiation from the atmosphere to the Earth's surface. Where this "extra" CO2 strikes land it will warm the surface, increase convection, conduction and radiation increasing surface atmospheric temperatures.
As we've already touched on - where the "extra" downward IR strikes the ocean the effect is much less clear. Does the "extra" energy mainly increase evaporation rates or does it lead to increased temperatures in the water column?
Looks like a good place to start; give me a day here to get my mind organized in terms of what I know, think I know, and what I've no clue about. Saves prying my feet from my mouth later.
  • · Replies 42 ·
9K
