Can Magnetic Fields be Reflected or Guided by Materials?
6 replies · 15K views
yashiekh
Are there any materials out there that can reflect magnetic fields, or can a twisted channel be formed for them to follow?
Not reflect ( that I know of )
There are materials that don't let magnetic fields through them ( superconductors or mu-metal ) and you can contain and direct a magnetic field in somthing like the soft iron core of a tansformer.
Like mgb_phys, examples of this is diagmagnetism which is a property of superconductors. It will repel any kind of magnetic field no matter what orientation. You can make it follow a twisted path. Like a twisted iron core for example, the magnetic field will go through the iron core, follow the twist, providing you also wound a coil around the twisted iron core following the twist
That's not quite accurate. A magnetic field will follow an iron core whether or not there is a coil around the core. An external magnetic field is attracted to the high-mu iron core, and then prefers to travel along inside it, as opposed to out in the air. That is the principle behind magnetic shielding, for example.
Could a magnetic field possible be channeled to follow a certain path by other magnetic fields?
I wouldn't think so, at least not at realistic field strengths.
