Can microwave em radiation interferes with radiowave em radiation?
Microwave electromagnetic radiation does not interfere with radiowave electromagnetic radiation, as confirmed by ESA regarding the Planck satellite's CMB data. Jupiter's magnetosphere emits radiowaves, but these do not affect microwave measurements. The detection of radio and microwaves necessitates different antenna sizes, with small microwave detectors poorly suited for long-wavelength radio waves. Additionally, waveguides used for microwaves absorb most radiowave energy before it reaches the detectors. Therefore, the two types of electromagnetic radiation operate independently in this context.
Romulo Binuya
Just a thought because of the anomalous Planck satellite cmb data, and the second largest continuous structure in our solar system that almost fried the pioneer probe... Jupiter's magnetosphere which is known emitting radiowaves.
Science news on Phys.org
Radiowaves from Jupiter do not influence microwave measurements at Planck.
Yes, that's what ESA said, all possible causes of measurement goofs were systematically eliminated.
It's not just that. Detecting radio and microwaves require different sized antennas/detectors. Small detectors used for microwaves are very bad at detecting long wavelength radio waves and vice versa. Also, if they are using waveguides to get the microwaves to the detectors, then practically all of the radio waves energy would be absorbed by the waveguides before they could arrive at the detector anyways.
Likes 1 person
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
