I Can Placing Earth Between 3 Black Holes Slow Down Time?
Joe Bond
I am just wondering if placing the Earth equidistant from 3 black holes that are spinnng would slow down time on the Earth, due to the time dilation effect. Would that give us more time to live?
Why do you need three? Being in orbit around one would do. And it only slows down the passage of time relative to observers far away from the black hole. For the inhabitants of Earth time would seem to pass normally. Nobody would have gained any extra time to watch Netflix before they died.
Likes berkeman, Dale and Joe Bond
Assuming of course we aren't past the event horizon yet we are relatively close
oh I see, that's sad. Thank you for your reply
Time dilation isn't something that you directly experience. Instead, the special and general theories of relativity entail something called differential ageing. This means that if you go and spend some time close to a black hole and then return, you may well be significant younger than someone who stayed at home. The reason for this is that you have taken a shorter path through spacetime. The length of your path through spacetime is precisely the amount of proper time that has elapsed for you. Proper time is what you experience.
So, although when you return you may be younger than the friends you left behind, you have literally experienced less time. In that sense you can't directly get the best of both worlds by ageing less yet experiencing the same amount of time to enjoy life. You need herbal remedies for that!
Likes cianfa72 and Joe Bond
thank you for your reply
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
