Can Rapid Inverter Switching Cause Harmonics in a DC Line?
The discussion centers on the potential effects of rapid inverter switching on harmonics in a DC line, particularly in the context of inverters connected to AC loads. Participants explore the relationship between the nature of the AC load and the harmonics that may be injected into the DC line, as well as the characteristics of the resulting waveforms.
  • Some participants suggest that rapid switching of an inverter can inject harmonics into the DC line, potentially causing variations in the voltage waveform.
  • One participant notes that an ideal inverter would not allow any ripple current on the input, but acknowledges that real inverters may not behave ideally.
  • There is mention of filtering techniques, such as bypass capacitors and series inductors, that are used to minimize the effects of harmonics on the DC line.
  • Participants discuss the unpredictability of the waveform, which may include square wave pulses that can drop the power supply voltage.
  • Some express uncertainty about the specific nature of the waveforms, indicating that they can vary significantly based on multiple factors, including the inverter type and load characteristics.
  • Questions arise regarding the specific type of inverter output (e.g., modified sine wave, PWM modulation) and the frequency range of interest for harmonics.
  • One participant shares a reference to a circuit diagram and FFT analysis, suggesting it may provide insight into the topic.
  • There are requests for more specific information regarding the application and goals of the inquiry, indicating that the discussion may be too broad for effective responses.
Participants express a range of views on the effects of rapid inverter switching on harmonics, with no clear consensus on the nature of the waveforms or the extent of the impact on the DC line. Some agree that harmonics are injected, while others emphasize the variability and complexity of the situation.
Limitations include the lack of detailed information about specific inverter types and applications, as well as the dependence on various factors that influence the waveform characteristics.
b.shahvir
Hi all, :smile:
My understanding of harmonics in general is quite sketchy and as a result my query might appear a bit lulu! :rolleyes: I tried the net but could not get suitable info on the same.
This is what I'm looking at;
Assume a battery hooked up to an inverter (1 phase or 3 phase doesn't matter). The output of the inverter is connected to a typical AC load. I do not know the relation between nature of AC load (resistive, inductive or capacitive) and hence the resultant harmonics injected into the DC line due to the same, hence I would be unable to elaborate on the same.
What I want to understand is; whether rapid switching of the inverter inject harmonics into the pure DC line? If so, what is their nature and waveform like? I would be grateful if someone could provide me some articles or an on-line link on the same.
Thanks & Kind regards,
Shahvir
You are asking a somewhat broad question. An IDEAL inverter will fully isolate the output from the input. No matter what kind of load is hooked on the output of an ideal inverter, current will be drawn from the DC source in a smooth manner. There will be no ripple current on the input. It all goes downhill from there.
Yes it does.
There is always a risk that any device where rapid switching is happening will let some of the energy from this switching escape back down the DC power line.
To avoid this, filtering is used. Bypass capacitors from the DC line to ground and series inductors in the line attempt to minimise this effect.
Often such devices are also enclosed in metal boxes to make the chance of radiated energy reentering the power line less likely as well.
There is another post like this on this page:
https://www.physicsforums.com/showthread.php?t=313451
See the 5th entry which has some circuit diagrams in it and you will see the extent of the bypassing that has to be used.
Notice the right hand diagram where 3 capacitors are used in parallel and two inductors are also used (in the left diagram ) to avoid this.
The waveform is unpredictable but would be related to the frequencies being used in the inverter. It would always be a variation imposed on the supply line. So, it is still DC but varying slightly (or a lot) from being perfectly smooth.
:smile: Thanx guys, but some waveforms will be of much help
Shahvir
The waveforms will vary.
One reason this happens is that the inverter will probably not be drawing constant current from the power supply. On peaks of current, the power supply voltage will drop.
The waveform in this case will possibly be pulses of square wave tending to reduce the power supply voltage below its steady value.
These pulses can be any shape from an actual square wave or they might be very brief pulses.
You might have a 14 volt supply with various shapes of square wave dropping the voltage down to 12 volts periodically.
Bypassing capacitors try to fill in the drops in power supply voltage
And if there is bypassing, this waveform will vary again depending on how effective the bypassing is at particular frequencies.
One waveform you are unlikely to get is a sinewave as inverters use rapid switching and this is what is likely to get back into the power supply line.
That's perfectly fine. I understand that the nature of waveform will depend on several factors, but a typical waveform would provide me an insight into the concept.
Thanx :smile:
Thanx :smile:
There aren't any
Thanx :smile:
There aren't any and topology varies.
Thanx :smile:
Don't know if this is what you have in mind, but might be of interest. Shown is the DC source current, it's FFT and the circuit from which it came - not mine - PSIM Demo.
Tell us more about this inverter. Is it's output a so-called "modified sine wave", which is really a square wave with some dead time? Or, is it outputting a fairly good sine wave, using PWM modulation? Or, is it the "stepped approximation" type (such as the Xantrex SW4024)?
Are you only interested in the high frequency harmonics, due to rapid switching edges, with frequencies up in the radio frequency range? Or, are you also interested in the harmonics of the line frequency (perhaps up to the 51st harmonic) caused by the inductance of the battery cable?
I think this what I've have in mind. However, the variables do not present detailed info.
But thanks very much for the attachment, I'm grateful for that. :smile:
Further inputs are welcome
Shahvir
Someone please guide me! Thanx :smile:
If you want further input, please post exactly what you are looking for, and what your application is. Inverters can be very noisy, both on the AC Mains output and the input DC supply. If you invest more in the cost of the inverter and the power lost/dissipation, you can have a cleaner output and less hash on the DC input.
Why are you asking this? What is your end goal? So far, your questions in this thread are a bit too open-ended for us to answer efficiently. I hope you understand that.
Really bad input waveform
------------------------------------ 0 volt levelBad input waveform Slightly better input waveform Good input waveform
VVVVVVVVVVVVVVVV vvvvvvvvvvvvvvvvvvvvvvvvvvv ------------------------------____________________________________________________________________0 volt level
These waveforms do not really have a shape and, on an oscilloscope, they usually cannot be synched to give a steady pattern. This means they just look like a noisy blur.
I agree. But this is not a project and my query is general in nature. I was just curious about typical waveform pattern for injected noise in DC line due to inverter switching. Thanx for reply. :smile:
Thanx very much for reply. :smile: A very innovative way to explain a concept i must say...I'm impressed! :wink:
Shahvir
17K
  • · Replies 17 ·
  • · Replies 50 ·
13K
17K
