Can somebody help me this interference question
  • Thread starter Thread starter ahk167
    Interference
The discussion focuses on calculating the phase shift of light as it travels through a medium with a refractive index of 1.400. It begins with determining how many wavelengths of light (750.0 nm) fit into a distance of 2020 nm in vacuum. The phase shift is calculated by finding the difference in wavelengths before and after the light enters the medium, then multiplying by 360° to find the full shift. Additionally, the equivalent shift within the range of 0° to 360° is also required. The problem hints at future concepts related to wave interference, despite not involving them directly.
ahk167
Light of wavelength 750.0 nm is sent along a route of length 2020 nm in vacuum. The route is then filled with a medium having an index of refraction of 1.400. In degrees, by how much does the medium phase shift the light? Give the full shift and then the equivalent shift which is between 0° and 360°
I have no idea how to start this question.
How many wavelengths would span this distance? (Include the fractional part!)
What does a medium with an index of refraction n do to the wavelength of light traveling through it? How many wavelengths within the medium would now span the 2020 nm distance?
The full shift would be the difference in these answers multiplied by 360º. How do you then find the "equivalent shift"?
BTW, this problem as it stands does not involve the concept of wave interference. (They're probably setting you up, though, for some that do...)
