Can someone check this for me please?
  • Thread starter Thread starter yoshi6
69 replies · 9K views
yoshi6 said:
okay is this one right?
2Ag + 2e- -> 2Ag0
isnt the cathode reaction: Ag+ + e- -> Ag
and the anode reaction: Ag-> Ag+ + e-
Is that significant at all?
correct and yes b/c it tells you what role they're playing, but you're able to recognize them so it's all good.
anyways
so we have
[tex]Ag^+ (aq) + e^- \rightarrow Ag (s) \ E^0 = +0.80[/tex]
[tex]Ni^{2+} (aq) + 2e^- \rightarrow Ni (s) \ E^0 = -0.28[/tex]
which becomes
[tex]2Ag^+ (aq) + 2e^- \rightarrow 2Ag (s) \ E^0 = +0.80[/tex]
DO NOT! multiply your charge by 2, Electrical potential is an intensive property just like density.
choosing Nickel to be our anode, we flip it's half-reaction
[tex]2Ag^+ (aq) + 2e^- \rightarrow Ag (s) \ E^0 = +0.80[/tex]
[tex]Ni (s) \rightarrow Ni^{2+} (aq) + 2e^- \ E^0 = -0.28[/tex]
notice how i didn't flip it's charge? there are two methods in dealing with whether you change your sign or not.
if you're using the equation [tex]E_{cell}=E_{cathode}-E_{anode}[/tex] keep your charges the same, if you're just going to add it all up without the equation, flip your charge with respects to the half-reaction you have chosen to be your anode.
so how would you write your overall reaction? (just add them up and cancel the electrons) and what is the EMF?
okay, i see...
Ag+(aq) + 2e- -> Ag(s) E0 +0.80V
Ni(s) -> NI2+(aq) + 2e- E0 -0.28V
_______________________________________
2Ag + Ni -> Ag + Ni2+ E0 0.52V
yoshi6 said:
okay, i see...
no, check your work again.
show me how you plugged your E0 into your equation or if you just flipped it.
yoshi6 said:
did i add them wrong?
yep
show me your work if you were to do it with the equation
Ecell = E cathode - E anode
= .80 - (-0.28)
=1.08 ?
= .80 - (-0.28)
=1.08 ?
correct
and if you just flip the equation and choose not to use the equation, you would've added and resulting in the same answer = +1.08
okay, awesome...I think I have some studying to do before first year starts...
alright, good luck! have fun
chemistry
I also need to do some chemistry :cry:; I have been planning to do it since last two months.
What are you going into, and if you don't mind, where?
If you are planning to really do it; then, you may try
http://www2.ucdsb.on.ca/tiss/stretton/CHEM2/organicx.htm
It has notes for all grade 12 topics/units!
Actually I only have to do it in first year. I am majoring in wildlife biology at the university of guelph.
wow! beautiful campus ...
you've been? Lol don't you live in texas?
i can be anywhere anytime ... <google> :biggrin:
it's nice tho, how's the weather? lol, it's way too hot down here.
ah isee...it is a really nice campus...well, I seem to think it is really hot right now, it's about 31 celsius, what about over there?
okay I have one last question that I am having trouble with. I am almost done my assignment. This is the last one...I have some examples in my book I am trying to follow, however, this is a little different.
If the Ka= 1.8 x 10^-5 for acetic acid (i.e . CH3COOH), what is the H+ ion concentration in a solution of this acid, if 1.2 grams of acid are dissolved in 1.0 L of solution.
So I assume I have to do this:
Ka= [H+][A-]/ [HA] ? and from there...
so you have 1.2 grams of acetic acid, and you're told it's dissolved in 1.0L sol'n, what would your next step be?
your Ka expression is correct, question tho, is H+ and H3O+ the same?
by analyzing the Ka, what would you estimate the pH to be?
yoshi6 said:
yes it is, isn't it?
yes, what would you estimate your pH to be?
[tex]CH_3COOH (aq) + H_2O (l) \leftrightarrow H_3O^+ (aq) + CH_3COO^- (aq)[/tex]
what values you would input in your EQUIL for your ICE table?
okay
Ka = 1.8 x 10^-5= (9.0 x 10^-3)^2
_____________
[CH3COOH]
At = , [CH3COO-] = [H3O+] = 9.0x10-3mol/L
I think...
okay that is supposed to be (9.0 x 10^-3)^2 divided by [CH3COOH]
yoshi6 said:
okay
_____________
[CH3COOH]
I think...
where did you get 9.0 x 10^-3?
wrong? I don't know I'm very confused, I am trying to follow the examples in my book, but I don't really understand what it going on...
[tex]K_a=\frac{[H_3O^+][CH_3COO^-]}{CH_3COOH}[/tex]
[tex]1.8\times10^{-5}=\frac{x^2}{\frac{[1.2/60.06]}{1.0}}[/tex]
you wrote your Ka correctly up there, idk what happened.
you're correct that the Acetate ion and Hydronium ion concentrations will be the same.
but where does the 60.06 come from? what is that
let me fix that, i should have that within another fraction
how do you calculate molarity? what units should/are used for equilibrium concentrations?
molarity = moles of solute/ liter of solution
what is the molar mass of Acetic acid and the moles of 1.2 grams of Acetic acid that will be dissolved?
