Can someone explain Compton scattering?
In summary, the conversation discusses Compton scattering, where an x-ray photon collides with a slow moving electron and transfers energy and momentum to it. This results in a change of wavelength for the photon and an increase in energy for the electron. The process is described by Feynman diagrams and is different from atomic absorption, which involves electrons in bound states. There is a debate about whether the Feynman diagrams represent an actual physical process or are just a guide for calculations. The term "virtual" is used to describe the state of the electron between absorption and re-emission, but its meaning is vague.
Coop
40
Hi,
My textbook describes Compton scattering the following way:
"...an x-ray photon...has a collision with a slow moving electron...the photon transfers energy and momentum to the electron [and recoils]..."
Is it not true that by definition when a photon collides with a particle it donates its energy in an all or none fashion depending on the particle's energy levels? I don't get how this x-ray photon is capable of only donating SOME of its energy.
Any help?
Thanks,
Cooper
The electron absorbs one photon and emits another.
The scattering is elastic, and in the center-of-energy frame the ingoing and outgoing photon have the same energy. But in the lab frame, the collision causes the electron to recoil, imparting some of the photon's energy to it. The process is described by these Feynman diagrams.
Likes 1 person
Atomic absorption requires an available energy level; in that case an electron "moves" to a higher energy state, and for emission there is a drop. This is what they study in spectroscopy.
Scattering is a different process: a particle arrives, has an interaction with the body (atom, nuclei, proton, etc) - and leaves. Rutherford's atomic model (1911) was inspired by nuclear scattering experiments.
In Compton's case very high energy photons are being scattered, and in doing so energy is transferred from the photon to the electron. This results in a change of wavelength for the photon, and a corresponding increase in energy for the electron.
See http://en.wikipedia.org/wiki/Compton_scattering
The easier explanation might be that the reason that an electron has to absorb a given amount of energy (discrete spectra) is that the electron is in a bound state (inside an atom) and therefore can only take on a discrete set of energy levels. In Compton scattering or Thompson scattering, the electron is free, and can take on a continuum of energy levels.
Thanks guys,
So is absorption actually taking place here or is it a different type of interaction? I am getting mixed answers.
The photon is scattering off the electron. The electron absorbs some of the energy and momentum. If you want to interpret the Feynman diagram as an actual physical process, then the electron is absorbing the photon, and quickly (immediately) re-emitting another one. But the Feynman diagrams are just a good diagrammatic way of solving for the S-matrix, so whether you take them to mean "physically" what's happening, is really up to you.
You start out with one photon and one electron, you end up with one photon and one electron, with some momentum and energy from the photon transferred to the electron. That's all QED can really say about the matter.
Likes 1 person
Indeed it is not known what physically does happen (see wikipedia), so everyone has his own believe. Probably one must limit to look what is going in and out, like Matterwave tells.
Likes 1 person
The usual terminology is scattering.
The Feynman diagram is not a literal representation, but rather a guide to setting up the calculations in a systematic way.
Likes 1 person
And in between the absorption and re-emission, the electron is virtual. (Cue the arguments about "real" versus "virtual" particles here. :rolleyes:)
I am not so fond about the word "virtual", because it is always vague what it means. What happens between input and output is real; we only don't know what it is.
Thanks a lot everyone :) I appreciate the input.
What is Compton scattering?
Compton scattering is a phenomenon in physics where a photon (particle of light) collides with an electron, resulting in the photon losing energy and changing direction. This occurs due to the transfer of energy and momentum between the photon and electron.
How does Compton scattering work?
Compton scattering occurs when a photon interacts with an electron. The photon transfers some of its energy and momentum to the electron, causing the photon to lose energy and change direction. This change in direction is known as a scattering event.
What is the significance of Compton scattering?
Compton scattering is an important phenomenon in understanding the behavior of light and electrons. It was first observed by Arthur Compton in 1923 and provided evidence for the particle nature of light. The study of Compton scattering has also led to advancements in medical imaging techniques.
How is Compton scattering related to the Compton effect?
The Compton effect refers to the change in wavelength of a photon after undergoing Compton scattering. This change in wavelength is known as the Compton shift and is used to calculate the energy and momentum transfer between the photon and electron in a scattering event.
Can Compton scattering be explained using quantum mechanics?
Yes, Compton scattering can be explained using quantum mechanics. The process involves the interaction of a photon and an electron, both of which have quantum properties. The theory of quantum electrodynamics (QED) is used to describe and predict the outcomes of Compton scattering events.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
