Can someone help me find an On1/On2/Both On/Off mini switch?
  • Thread starter Thread starter richleyance
    Switch
The discussion centers around finding a specific type of mini toggle switch that can accommodate multiple circuits in a compact space. Participants explore various switch configurations and their applicability to the user's project involving a battery, LEDs, and a laser.
  • One participant is searching for a mini toggle switch suitable for a small space, specifically for a project involving a 3.7V battery and multiple circuits.
  • Another participant questions the current and voltage requirements for the switch, suggesting that this information may help in finding a suitable product.
  • A suggestion is made that a 2P4T mini slide switch might be the appropriate type, prompting others to search for it online.
  • There is a proposal to use an on/off/on switch to control different circuits, with one circuit powering a plug for charging and another for an integrated circuit.
  • Another participant mentions that mini-toggle switches typically come in two or three positions, and suggests using independent single pole switches to achieve the desired functionality.
  • One participant recalls rotary switches with multiple positions as a potential alternative, while expressing concern about the safety of using a 2W laser in the project.
  • There is a reiteration of the difficulty in finding a toggle switch with four positions, indicating that the advice given may be worth considering.
Participants express uncertainty about the availability of the desired switch type, and multiple competing views on the best solution remain unresolved. There is no consensus on a specific switch that meets the user's requirements.
Participants discuss various switch configurations and their implications, but there are limitations in terms of the specific requirements and constraints of the user's project that remain unaddressed.
richleyance
I've been searching for one of these switches to no avail, perhaps any of you might know where i can get one?
And it has to be a mini toggle switch because I am working with a very small space.
Hi richleyance.
I have no idea whether such a thing is marketed. We'll see...
Roughly what current and voltage will it need to carry?
https://www.physicsforums.com/attachments/holly-1756-gif.110502/
NascentOxygen said:
Hi richleyance.
[PLAIN]https://www.physicsforums.com/attachments/holly-1756-gif.110502/[/QUOTE]
well I am going to be running a 3.7V 1400mAh battery on it. On the first side I am going to be running a 30mA resistor, and on the second side I'm going to have a plug that I will use to charge the battery and I'm also going to be running another circuit off of it through the plug. So basically on one circuit I'm going to be powering a few LEDs and on the other circuit I'm going to be running LEDs and a 2W laser.
I think it will be called a 2P4T mini slide switch
2 poles, 4 throws/positions
Try a google search to see whether that's the item.
I don't suppose I would be able to use an on/off/on switch but wire one circuit to one on and both circuits to the other on and have it work that way would I? So this way the single on would only power the plug for charging and a separate circuit while the on with both will allow me to have both the integrated circuit and the plug circuit running at the same time.
That would be a single pole, 3 positions switch, 1P3T. Just don't wire anything to the middle position so it will be an OFF.
Mini-toggle switches usually come in two or three position. Three position switches have centre position off. I have never seen 4 position mini-toggle switches. Maybe you could use an independent pair of single pole, two position mini-toggle switches next to each other. That would give those combinations.
Sometimes you have to make-do with what's available.
I'm thinking of old rotary switches for lamps
four positions: one bulb, other bulb, both bulbs, off.
https://www.1000bulbs.com/product/137501/ELEC-55374610.html
a two watt laser ? This thing stays indoors i hope, and isn't around people.
Indeed. That thing could "Shoot Your Eye Out".
That is simple with a little logic and relays. What is your background, and what exactly are you trying to do?
You want a 2 Gang - 4 Position rotary switch.
I have yet to see a toggle switch with 4 positions. So, much of the advice given here so far is well worth considering.
  • · Replies 49 ·
  • · Replies 33 ·
  • · Replies 19 ·
  • · Replies 42 ·
  • · Replies 31 ·
