Can the fullness of a cylinder of water be determined by its frequency
In summary, the conversation discusses determining the height L of a high cylinder filled with water and air, based on the frequency of the sound produced when the cylinder is hit. The conversation mentions using the velocity of sound and the cylinder's modes of vibration, particularly the vibration of the air column. The conversation also considers simplifications, such as assuming the vibration of the air, and mentions the importance of knowing whether the cylinder is open or closed at the top. Finally, the conversation briefly discusses the use of theory and experimentation to determine L.
tsuwal
105
We have high cilinder with height h a filled with water up to the height L<h and air in the rest. We hit the cylinder and listen to the frequency of its sound. How can we determine L in function of h, the frequency of the noise, the speed of sound, ...
Maybe the sound has something to do with the harmonics on a string. Is the frequency =velocity of sound/(2*(h-L))?
You don't say whether it is hit above or below the water line.
In general this could be pretty complex. The cylinder will have several modes of vibration that are affected by the water depth. There'll be a bulk vibration within the water-filled part, vibration in the air column, and vibrations in the cylindrical wall above the water (both vertically and radially). Pick one that you think will be affected.
if we made a simplification like just assmuning the vibration of the air, could qe solve it?
Yes, but to complete the picture for that vibration we'd need to know whether the cylinder is open or closed at the top. Do you know about nodes, antinodes, standing waves in pipes...?
yes. the cylinder is closed at the top
OK, so how many wavelengths can be in the air column in general?
nodes are located at the extremeties, so using my variables 2(h-L)/n But i don't know if experimentally this can be verified...
I don't understand why you are looking for experimental verification. I thought the idea was to use theory (which could be verified by experiment if required) to come up with a procedure for judging L from the sound.
1. Can the fullness of a cylinder of water be determined by its frequency?
No, the fullness of a cylinder of water cannot be determined solely by its frequency. The frequency of a cylinder of water may be affected by factors such as the size and shape of the cylinder, the type of material it is made of, and any objects or particles within the water.
2. What factors affect the frequency of a cylinder of water?
The frequency of a cylinder of water may be affected by factors such as the size and shape of the cylinder, the type of material it is made of, and any objects or particles within the water. Other factors such as temperature and pressure can also impact the frequency of the water.
3. How is frequency measured in a cylinder of water?
Frequency in a cylinder of water can be measured using a variety of methods, including using a sonar device or by measuring the time it takes for waves to travel through the water. The units for frequency are typically hertz (Hz).
4. Can frequency be used to determine the volume of water in a cylinder?
No, frequency cannot be used to accurately determine the volume of water in a cylinder. While there may be some correlation between the two, other factors such as the shape and size of the cylinder, as well as any objects or particles in the water, can greatly impact the volume of the water.
5. Can the fullness of a cylinder of water be determined using other methods besides frequency?
Yes, there are other methods besides frequency that can be used to determine the fullness of a cylinder of water. Some common methods include using a ruler or measuring cup to physically measure the volume of the water, or using the weight of the water to calculate its volume.
