Can Voltage, Current, Resistance, and Length Determine a Wire's Fusing Factor?
  • Thread starter Thread starter Ga San Wu
The discussion focuses on determining the fusing factor of a wire using voltage, current, resistance, and length. The experiment involves a constantan wire with a specified length, voltage, and current, leading to a calculated resistance. A participant shares an equation for calculating the fusing current, which incorporates Preece's Constant and the wire's diameter in inches. The equation presented is I_f = C * d^(3/2), where I_f represents the fusing current. This approach aims to clarify the relationship between these electrical properties and the fusing factor.
Ga San Wu
hi all,
ive been doing an experiment to do with fusing factors and unfortunately i didnt read
my experiment coursework sheet properly and have only recorded the current going
through a wire at a certain voltage. the results have then been used to work out the resistance,
i was wondering whether there was an equation to work out the fusing
factor with only the voltage, current, resistance and length
for example,
3cm length constantan wire
0.2v across the wire
reads an average of 3.01Amps
the resistance is therefore 0.07
i have read an old question that is exactly what i am doing but i am still rather confused.
anyone know anything about this?
Julien
i have had time to try and answer my question.
so far i have come up with one equation that seems
to answer most of my problems.
the equation is as follows (lets hope i can use this symbol thing properly!)
\\I_f = \\C \\d^\frac{3}{2}(Hurrah the symbols worked!)
\\I_f is the fusing current
\\C is Preece's Constant ( it depends on which material you use)
\\d is the diameter but be careful it has to be in inches
