tade
- 720
- 26
Is it possible, and if so, how should we modify a typical oven magnetron so as to produce higher frequencies of EM radiation?
tade said:![]()
I know, but with modifications?davenn said:no, they are designed to oscillate at a specific frequency
change the frequency so as to resonate with the other components of food, besides the water in food.davenn said:and what dangerous things were you planning to do with 100's of Watts of microwave power ?
tade said:… change the frequency so as to resonate with the other components of food, besides the water in food.
Wikipedia said:Sometimes, microwave heating is explained as a resonance of water molecules, but this is incorrect; such resonances occur only at above 1 terahertz (THz).
Wikipedia said:The microwave frequencies used in microwave ovens are chosen based on regulatory and cost constraints. The first is that they should be in one of the industrial, scientific, and medical (ISM) frequency bands set aside for non-communication purposes. For household purposes, 2.45 GHz has the advantage over 915 MHz in that 915 MHz is only an ISM band in the ITU Region 2 while 2.45 GHz is available worldwide. Three additional ISM bands exist in the microwave frequencies, but are not used for microwave cooking. Two of them are centered on 5.8 GHz and 24.125 GHz, but are not used for microwave cooking because of the very high cost of power generation at these frequencies. The third, centered on 433.92 MHz, is a narrow band that would require expensive equipment to generate sufficient power without creating interference outside the band, and is only available in some countries.
i need magnetron specifics thoughBaluncore said:
What specifics ?tade said:i need magnetron specifics though
