Can you find tension on a string without mass
In a pulley system with three masses, two are hanging while one is on a table, with the right mass being twice the left's mass. The discussion revolves around whether the system is in mechanical equilibrium. Participants suggest drawing free body diagrams for clarity on the forces acting on each mass. The key question is about the sum of forces on each mass and the implications of setting them to zero. Understanding these forces is crucial for analyzing the tension in the string despite the absence of mass values.
faisalcrazy
So my pulley system has 3 masses two of which are connected to a center mass on top of a table. No mass was given for any of the objects but of two masses hanging from the table, the one on the right is 2 times the mass on the left. I hope I haven't confused you but its like a three step diagram so I'm going to try make a picture for you
M2(free weight)-----^M1(on table)------M3(free weight,X2 the mass)
Are the weights supposed to be in mechanical equilibrium? I recommend drawing a free body diagram for each mass.
Yes they are and I have! it was also given with a free body diagram that's why I tried to draw it out for you
What forces do you get acting on each mass? What happens when you set the sum of the forces on each mass to zero?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
