Can you harvest a sails energy withouth movement?
  • Thread starter Thread starter dboy18
    Energy Movement
Harnessing wind energy through stationary sails presents challenges, as energy generation requires motion. While modern sails can act as airfoils, they are less efficient than wind turbine blades, which are designed for optimal performance with high aspect ratios. The discussion highlights that force without movement does not produce energy, emphasizing the need for dynamic systems in energy generation. Additionally, the principles of energy conservation apply to other renewable sources, such as solar panels. Overall, innovative designs must consider the necessity of motion to effectively generate power.
dboy18
I was thinking of new ways to harness windenergy. A sail produces a lot of power, could you somehow harvest this energy, if you had a modern computercontrolled kevlar (or something akin) sail attached to the ground; i.e having no forward movement.
Pressure to electricity or something like that?
Think about it; minimal moving parts, virtually no noise, and beautiful to behold...
You can't generate power without some motion. Force with no motion generates no energy at all. In addition, modern sails act as airfoils, which is why a modern triangular rigged sailboat is so much faster than an older square-rigged craft. The airfoils on wind turbines are much more efficient and lower loss than any sail, due to their extremely high aspect ratio and careful shaping.
Yep, that's even true with solar panels. The momentum of the absorbed photons is conserved.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
