Can you have binary stars with the same radius but different masses?
Binary stars with the same radius but different masses are theoretically possible, particularly in close binary systems. However, mass typically dictates a star's radius, especially during the main sequence phase, where coeval stars formed from the same material will likely have similar compositions and thus similar masses. When one star evolves off the main sequence, it may expand, but more massive stars evolve faster, complicating the scenario of matching radii. If both stars fill their Roche lobes, their radii can differ despite mass differences, but generally, similar physical properties lead to similar masses. Overall, while rare, the existence of such binary stars is acknowledged within the galaxy.
AussieDave
The title speaks for itself. I'm just curious and I couldn't find anything on it. Particularly, what if they are a close binary (period less than 50 days)?
Astronomy news on Phys.org
I think there are a few problems with this. For a main sequence star, mass determines most of the other properties, including radius. For more information, see here:
http://en.wikipedia.org/wiki/Main_sequence
Well, supposedly chemical composition affects things as well. But if the stars are in a binary system, then they are probably coeval, which is fancy astronomer talk for, "they formed at the same time." They also probably formed from the same cloud of material too, so presumably their chemical compositions are similar. So, if they have very different masses, then they are going to have very different radii, when both of them are in the main sequence phase of their lifetimes. Okay, well, what if one star is a low mass and therefore small radius star, and the other one is high mass and much larger? Isn't it conceivable that once the small star evolves off the main sequence and becomes a red giant, that it can enlarge to attain a radius comparable to its much larger companion? The stars will then have similar radii but still very different masses. Answer: NO. The problem with this is as follows: more massive stars have much much shorter main sequence lifetimes than lower mass stars. So in the binary system in this scenario I've proposed above, it is actually the larger of the two companions that will evolve off the main sequence first, becoming a red giant (and a very big one at that).
This is probably the most common origin for binary stars, but sometimes stars do capture each other or even collide. So OP's senario, while rare, probably does exist somewhere in our galaxy.
Interesting, thank you for the replies. I am most interested in close binaries, in which case a captured case would I think be extremely rare.
Even a solitary star, in the course of after main sequence evolution, will undergo repeated expansions and contractions. And in the end, become much smaller than any main sequence star.
In case of a close binary, the evolution after main sequence is very different because a star which expands overflows into the other.
And the star receiving the overflow changes both its mass and radius.
Now, if both stars are filling their Roche lobes then the radii of Roche lobe are different for different masses. However, if they do not, they can have same radius for different masses.
Simply put, if they are identically constituted by virtue of physical properties, then they are similar to one another as directly proportional to the relation of the radii. On the other hand, if the stars of the binary system are, although uniform, different in composition, then they are, in all probability, of distinct masses. A helium balloon is obviously going to be considerably lighter than a mound of bricks around the same dimensions. However, as accordingly noted by several people already, as the stars are coeval*, the stars likely have similar compositions in addition to eual radii and therefore should have about the same mass in collective consideration.
*Matter + manner of conglomerative accretion + time = recipe for star formation. In this case, the variables are all the same, so it seems that most partners, if not all binary systems, should, in theory, have virtually the same mass per unit^3. In example, the should have the same total mass given equal radii.
Cheers, newcomer from Earth.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
