I How do canonical transformations relate to Hamiltonians?
  • I
  • Thread starter Thread starter dyn
    Transformations
Canonical transformations relate Hamiltonians through a numerical equivalence rather than identical functional forms. The Hamiltonian for a harmonic oscillator, H(p, q), and the transformed Hamiltonian K(P, Q) can yield the same numerical results when evaluated at corresponding values, despite their different expressions. The distinction arises from the use of different coordinate systems, such as Cartesian versus polar coordinates. K and H being equal in value does not imply they share the same functional form, which only occurs under specific symmetries. Understanding this relationship is crucial for grasping the broader concept of canonical transformations in Hamiltonian mechanics.
dyn
Hi
The Hamiltonian for a harmonic oscillator is H = 1/(2m) ( p2+m2ω2q2). A canonical transformation is then made to a new Hamiltonian K( P , Q )
It is said that K ( P , Q ) = H ( p , q ) but K ( P , Q ) = ωP ( cos2Q +sin2Q ) = ωP
I don't understand how K ( P , Q ) = H ( p , q ) when they have different forms ? I thought if K = H then they must have the same form but H is a sum of 2 squares but K just equals ωP
Thanks
They have different forms for different parameters, i.e. (P,Q) and (p,q). One uses Cartesian coordinates. Another uses polar coordinates.
Thank you. I think i might be getting confused with symmetries , so let me see if i have got this right.
K ( P , Q ) = H ( p , q ) means that if i evaluate H at a certain value of p and q and then evaluate K at the transformed values of P and Q i get the same numerical answer ? There is no implication that K and H have the same functional form ?
If K and H had the exact same functional form then i could write H ( P , Q ) = H ( p , q ) and this occurs when the canonical transformation is a symmetry ?
Is that right ? Thanks
K and H does not have the same function form. Q does not appear in Hamiltonian K, which is called cyclic coordinate. Hamilton equation of motion for conjugate momentum is
\dot{P}=0
The generating function of transformation is
\displaystyle W_{1}(q,Q)={\frac {1}{2}}m\omega q^{2}\operatorname {cot} {Q}
This post is a general question. It is not specific to the harmonic oscillator. I am just trying to find out if i understand the concept in general terms ?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
