Is x^2 + y^2 = 4R^2 a Cylinder or a Circle in 3D Space?
  • Thread starter Thread starter whatisreality
The discussion clarifies that the equation x^2 + y^2 = 4R^2 represents a right circular cylinder in three-dimensional space, as z can take any value, making it arbitrary. While the equation describes a circle in a two-dimensional plane, stacking circles along the z-axis forms a cylinder. Participants express confusion about whether they are integrating two shapes or one, but it is established that the equation pertains to a single cylindrical shape with varying z values. The importance of understanding that z's absence from the equation does not limit its value is emphasized. This clarification aids in comprehending the integration process for calculating the volume V.
whatisreality
I don't think this goes in the homework section because I don't actually want help answering the question, I want to know what it means!
Consider the volume V inside the cylinder x2 +y2 = 4R2 and between z = (x2 + 3y2)/R and the (x,y) plane, where x, y, z are Cartesian coordinates and R is a constant. Write down a triple integral for the volume V using cylindrical coordinates. Include the limits of integration (three upper and three lower). Evaluate the integral to determine the volume V in terms of R.
My main problem is when it asks about the cylinder x2 +y2 = 4R2. I'm nearly 100% sure that equation is not actually for a cylinder but for a circle! And I'm not entirely clear on whether I'm integrating two shapes, as in two volume integrals, or it's describing just one big shape.
In the latter case, I still don't know where cylinders come into it.
Mathematics news on Phys.org
The equation is for a circle but you also have that ##z## varies between the ##xy##-plane and ##(x^2+3y^2)/R##. If you stack a lot of circles on top of each other you get a cylinder. So the first equation only describe one part of the cylinder while the third coordinate, ##z## is free too change value.
So the equation is a circle if you were in a plane, If you were in 3d-space you have an infinite cylinder if you didn't have any restrictions on ##z##.
Likes whatisreality
I draw the shape of that cylinder with R=1.
Likes whatisreality
In three dimensions (which is implied by the statement that x, y, and z are coordinates), the equation (##x^2 + y^2 = 4R^2##) is a right circular cylinder. Since z does not appear in the equation, it is arbitrary.
Arbitrary as opposed to zero?
"Arbitrary" means "any value."
I know. So arbitrary means it can take the value zero and others, as opposed to just zero, which is what I thought the equation meant. Shouldn't the z appear somewhere in the equation though? I feel like this is quite a basic concept I've misunderstood or missed! Oops!
No, z doesn't have to appear in the equation. In the plane, the equation x = 2 is a vertical line. Here, y is not mentioned, and it is arbitrary, so every point in the plane with coordinates (2, y) is a point on this line. The situation is similar for your cylinder equation.
Likes PeroK and whatisreality
Oh, I get it! Ok, that is a really important thing to know. Also know what the question is asking now! Thanks for your help :)
