What Happens to the Voltage Across a Capacitor When the Plates are Separated?
  • Thread starter Thread starter gracy
    Capacitance Pdf
When the plates of a disconnected capacitor are separated, the voltage across the capacitor increases because the charge (Q) remains constant while the capacitance (C) decreases. The relationship Q = CΔV indicates that as C decreases, ΔV must increase to keep Q constant. A referenced PDF incorrectly states that voltage decreases, which is deemed wrong by participants in the discussion. Participants confirm that the formula presented in the PDF is also incorrect. The consensus is that the voltage across the capacitor indeed increases when the plates are separated.
gracy
A capacitor has a capacitance C and is charged using a battery. After disconnecting the battery the two plates are separated until they are twice as far apart as originally. What happens to the voltage across the capacitor?
I think answer should be voltage increases . As battery has been disconnected q will remain same . Distance between the plates is increasing , capacitance should decrease.
##Q##= CΔV
As Q is constant and C is decreasing , V should increase.
But according to http://www.bama.ua.edu/~tmewes/PH-106/2008/clicker%20questions/CH26%20Clicker.pdf
Go to page 10
Voltage goes down . It is wrong . And formula is also wrong. Is that correct?
I have gone through all 14 pages of this pdf and found them right except this one , but I want to confirm are all other 13 pages correct?
Go to page 10
I agree with you ... it may have been a genuine highlighting mistake ?it increases because you do work on the system to spread the plates, this results in an increase in potential energyDave
Likes gracy
Yes, the formula is wrong on that page.(10)
Likes gracy
##Q= CΔV##
Go to page 10
You are right.
Solving ##\ Q= C\,ΔV\ ## for ΔV gives ##\displaystyle\ \Delta V = \frac QC \ ##.
That pdf / PowerPoint has the incorrect ##\displaystyle\ \Delta V = \frac CQ \ ##.
