Capacitance Calculation for Powering Pulsating Load: 100mA for 10mS at 3.3V
  • Thread starter Thread starter Neo11
    Calculation
To power a pulsating load of 100 mA for 10 ms at 3.3V, a capacitor value must be calculated to ensure it can deliver the required current. The power supply provides only 2 mA, necessitating the capacitor to store sufficient charge to meet the load's demands. The relevant equation for this calculation is i(t) = C * (Δv/Δt), which relates current, capacitance, and voltage change over time. Additionally, determining the time required to charge the capacitor is crucial to ensure it can handle the current surge effectively. Proper calculations will enable the design of a circuit that meets the pulsating load requirements.
Neo11
I want to build a small circuit which will power a pulsating load. I got a power supply which can provide 3.3V and 2 mA. Now my load requirement is 100 micro amp average and 100 mA for 10 mSec(all at 3.3V). I want to calculate
1. Value of capacitor which will provide 100mA for 10 mS
2. Time duration to sufficiently charge the capacitor(to determine after how much time load current surge can be adjusted)
Can anybody help me to solve this problem?
The equation you want to use is:
i(t) = C \frac{dv(t)}{dt}
Or in simpler form (if you haven't studied calculus):
i(t) = C \frac{\Delta v(t)}{\Delta t}
or,
\frac{i(t)}{C} = \frac{\Delta v(t)}{\Delta t}
This means that the droop in voltage with respect to time is equal to the current out of the cap, divided by the size of the cap.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
