Capillary Rise and Pressure in Sealed Capillary Tubes
  • Thread starter Thread starter zorro
    Capillary Rise
Capillary rise in a sealed capillary tube does not significantly differ from an open tube, as surface tension remains constant. However, if gas is trapped above the liquid, the pressure from that gas can reduce the height of the liquid column. The pressure at a horizontal point in the tube is generally equal to atmospheric pressure plus the height of the liquid column, unless the tube is sealed. In a closed system, the balance of pressures must account for both the fluid column and the capillary effect. Understanding these dynamics is crucial for accurately predicting fluid behavior in capillary tubes.
zorro
Will there be any difference in capillary rise if the capillary tube is sealed at one end?
What is the value of pressure at a point in the capillary tube on the same horizontal level as that of liquid outside? - Is it equal to the atmospheric pressure + the height of liquid column above it?
Practically, no difference will be observed because the surface tension doesn't vary.
There will be a difference if there is gas trapped above the fluid. The pressure in the gas will reduce the hight of capillary column.
It isn't entirely correct, but you can usually think of capillary effect and osmotic pressure as actual contributions to pressure, then you just solve until pressures equalize. So you have pressure from the fluid column pulling it down plus the external pressure doing the same. You have pressure in the fluid (E.g. atmospheric pressure, if there is an opening somewhere) and capillary effect pushing fluid up. Find a point where they all balance, and you are done.
If the capillary tube is open and the container with fluid is exposed to atmosphere, then you have the atmospheric pressure balance itself above and bellow your column. Then all you have to do is compare pressure from column's height to effective "negative" pressure generated by the capillary effect. If you close one end, or you close the container with fluid, you have to take that into account.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
