Optimizing Heat Exhaust Capture for Natural Gas Fired Industrial Heaters
  • Thread starter Thread starter Jake Platt
    Exhaust Heat
Capturing 24 hours of heated air exhaust from a natural gas-fired industrial heater, which emits 70,000 CFM of 190F air, is impractical due to the immense volume required for storage. Calculating theoretical compression ratios and tank volume reveals that a single tank would be insufficient and inefficient for this purpose. The discussion shifts towards utilizing energy from the exhaust, suggesting alternatives like the Brayton cycle for energy recovery. Additionally, the need for an effective air filtration system is emphasized, as current systems cannot handle the high flow rate, and addressing the source of pollutants is crucial. Ultimately, the focus is on environmental pollution control rather than decontaminating already polluted materials.
Jake Platt
Given a natural gas fired industrial heater dryer which gives off 70,000 CFM of 190F air at 1.1 atm air pressure, is it practicably possible to capture 24 hours worth of this heated air exhaust into a compressed storage tank?
How would I calculate the theoretical maximum compression ratios and tank volume requirements?
There's no way you could store that kind of volume in a single tank, and doing so would be a losing proposition anyway. http://www.wolframalpha.com/input/?i=70000+cfm+*+24+hours".
I'm getting the feeling you're actually interested in capturing/utilizing/storing the energy in the exhaust from the dryer, which could possibly be done with some sort of http://en.wikipedia.org/wiki/Brayton_cycle" , which assuming atmospheric temperature is 75 F will be 17.5% (but if it's "free" energy, who cares? Run a generator and pipe that energy back into the dryer...)
Thank you. Actually, our goal is ultimately to filter the air to remove suspended Nox or VOC particulate matter but the air filtration system cannot handle 70,000 CFM so we were considering compressing and storing the air so we can filter it later at a metered, controlled rate. But alas, it seems that won't work either. Any ideas??
Get a filtering system that can keep up with the flow rate, or look into additives or secondary processes that reduce NOx?
If you are getting enough pollutants to need filtering, that suggests there is something wrong with your gas burners, or you are using low quality gas.
In any case, the pollutants have presumably already contaminated whatever you are drying before you would filter them from the exhaust.
The natural gas combustion is what creates the NOx. We are talking about environmental pollution control not decontamination of a polluted process. The process starts with clean agricultural commodities at 80% moisture and ends with the commodities at 10% moisture and voluminous quantities of heat exhaust from the natgas combustion that has suspended VOC's and NOx emmissions.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
