Car Collision Problem: Determining Location and Speed at Collision
  • Thread starter Thread starter Math_Monster
    Car Collision
The discussion revolves around a physics problem involving a red car and a blue car approaching each other at different speeds and with specific braking capabilities. The red car travels at 30.0 m/s and the blue car at 25.0 m/s, starting 200 meters apart. Calculations show that both cars will collide, with the red car stopping at 132 meters and the blue car at 103.8 meters. To determine the exact collision point, the distance each car travels as a function of time is analyzed, leading to the equation X_r + X_b = 200 at the time of collision. The solution requires further calculations to pinpoint the exact location of the collision.
Math_Monster
A red car with speed 30.0m/s and a blue car with speed 25.0m/s are initially 200m apart and heading toward each other on a one-liner road. The brakes on the red car can produce an acceleration of 3.40m/ss while the breaks on the blue car can produce an acceleration of 3.25m/ss.
A) Do the cars collide? If yes, where?
B) If they collide find speed of each car upon collision.
I found out both cars' locations if the final velocity is 0, I also found where the time it takes each car to have a velocity of 0. The red car reaches v=0 at 132m and the blue car reaches v=0 at 103.8 m. So clearly they crash because 103.8 < 132. How do I find out WHERE they crash?
Write down the distance each car goes as a function of time, X_r and X_b. You also know X_r + X_b = 200 (with a particular choice of coordinates for each car) at t = t_collision.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
