Carnot Refrigerator Work Input: 230 J Extracts 346 J Heat
In summary, according to the conservation of energy, the work done to extract heat from the cold reservoir should not be more than the heat extracted.
Mohammed Alqadhi
If a Carnot refrigerator requires a work input of only 230 J to extract 346 J of heat from the cold reservoir.
Doesn’t this discrepancy imply a violation of the law of conservation
of energy?
Science news on Phys.org
Does it? Please state your reasoning.
My reasoning to that is it does not violate the 1st law because the heat Qh that will be rejected will be bigger than the extracted Qc.
what I wondering is how 230J of work results in 346J of heat?
According to the conservation of energy, 230J of work will be converted,If so, to 230J of heat or any other kind of energy, is that right?
Why not look up the carnot engine equations and do some math?
The work is the extra energy that has to come from outside in order to get the heat to flow "backwards" against the temperature gradient between the two reservoirs ... the gas starts out with 346J, and ends up with 576J. You had to do 230J of work to do that. The simple model does not tell you exactly how this happened.
I may not deliver my question right or you may not got it.
Anyway I did the math and it get out right, but I am asking that the work applied to the refrigerator to extract the heat from the cold staff should not be equal or more than the heat extracted?
It's like carrying a 5kg weight up 4.7m of stairs ... that would mean you have to do 230.3J of work.
If the bottom of the stairs was 7.3m above sea level, maybe the house is on a hill, then the energy of that 5kg weight was 357.7J
So you just did about 230J of work to extract 357.7J from the bottom of the stairs.
I understand this, but how is that related?
How much gasoline does it take to transport 1000 gallons of gasoline 100 yards down the road?
Likes hmmm27 and billy_joule
We get the volume and the distance, if I am correct about it what's the formula that gives us the work done, so we can find the amount of gasoline by using Q=mLc?
I don't want you to get bogged down in the detail. The point I am making is that that moving energy from one part of a system to another (eg from cold to hot reservoir) is not the same as adding energy to a system. There is no law that says moving energy costs more energy than the energy being moved.
A lorry might consume less than 1gallon moving 1000gallons that short distance.
Perhaps worth reading up on "closed systems" as conservation of energy only applies to those. If you don't include a hot reservoir in your system it's not closed.
This helps a little, but I am still confused!
Related to Carnot Refrigerator Work Input: 230 J Extracts 346 J Heat
What is a Carnot Refrigerator?
A Carnot Refrigerator is a theoretical refrigeration system that operates on the Carnot cycle, which is a reversible thermodynamic cycle. It is used to transfer heat from a cooler environment to a warmer environment, and requires no external power source to run.
How does a Carnot Refrigerator work?
A Carnot Refrigerator works by using a working fluid, such as a gas, to absorb heat from a cold reservoir and then release it to a hot reservoir. This process is repeated in a cycle, and the work input is used to compress the working fluid and move it through the system.
What is the work input for a Carnot Refrigerator with 230 J heat extraction and 346 J heat rejection?
The work input for a Carnot Refrigerator can be calculated using the equation W = Qh - Qc, where Qh is the heat extraction and Qc is the heat rejection. In this case, the work input would be -116 J, indicating that work is being done on the system.
Why is the work input for a Carnot Refrigerator negative?
The work input for a Carnot Refrigerator is negative because work is being done on the system, rather than by the system. The compressor in the refrigerator requires external power to operate, making the work input negative.
What factors affect the work input of a Carnot Refrigerator?
The work input of a Carnot Refrigerator is affected by several factors, including the temperature difference between the hot and cold reservoirs, the type of working fluid used, and the efficiency of the system. A larger temperature difference and a more efficient system will result in a lower work input.
  • Materials and Chemical Engineering
18K
