Cars A and B are d=60m apart and travelling at u(A)=8.8
  • Thread starter Thread starter teng125
    Cars
Cars A and B are initially 60 meters apart, with speeds of 8.89 m/s and 6.67 m/s, respectively. After 45 seconds, car A applies brakes to avoid overtaking car B, resulting in a collision. The user attempts to use the equation s=ut + 1/2a(t^2) to find the uniform deceleration of car A but struggles to arrive at the correct answer. The correct deceleration value is determined to be 0.0395 m/s². The discussion emphasizes the importance of correctly applying kinematic equations to solve motion problems.
teng125
cars A and B are d=60m apart and traveling at u(A)=8.89 and u(B)=6.67.knowing that 45s after driver A apply his brake to avoid overtaking B,the two cars collide,determine the uniform deceleration of car A.
i have tried to form eqns using s=ut + 1/2a(t^2) for both cars and substitute into [car A-car B=60] and can't find the answer.
the answer is 0.0395.
pls help...thanx...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
