Casual Function? (Electrical Engr)
  • Thread starter Thread starter m453438
    Function
The function presented is analyzed for causality, with the equation indicating that the output y(t) depends on the input x(t) at a future time t + 1. The initial reasoning suggested that the system is causal, but this was refuted by the observation that the output at any given time relies on future input values. The conclusion drawn is that the system is non-causal due to this dependency on future inputs. The discussion emphasizes the importance of understanding causality in electrical engineering systems. Overall, the analysis confirms that the system violates causality principles.
m453438
Causal Function? (Electrical Engr)
I have the following function:
d^2 y(t)/dt^2 + 3* dy(t)/dt + y(t) = dx(t)/dt +2x(t+1)
Where y(t) is the output and x(t) is the input.
I need to determine if it is causal or non causal.
See above.
My solution is that is causal since I can substitute t_1 = t+1 and t = t_1 -1, substituting this into the equation given:
d^2 y(t_1 -1)/dt^2 + 3* dy(t_1 -1)/dt + y(t_1 - 1) = dx(t_1 -1)/dt +2x(t_1)
And then if we say that t_1 = 0, I get:
d^2 y(-1)/dt^2 + 3* dy(-1)/dt + y(- 1) = dx(-1)/dt +2x(0)
And according to the definition, the equation does not depends on future inputs. Is my reasoning correct?
Thank You.
No, your reasoning is not correct. Just by inspection of the equation, the system is
non-causal because the value of the output y at time t depends on the value of the input x at time t + 1 (one time step into the future).
Even with the change of variables you did (which didn't actually do anything): clearly if the output of the system at -1 sec depends on the input to the system 1 sec later at 0 sec, then causality is being violated.
Thank You cepheled.
