Cauchy problem, method of characteristics
  • Thread starter Thread starter math2011
    Cauchy Method
math2011
This question is also posted at (with better formatting): http://www.mathhelpforum.com/math-help/f59/cauchy-problem-method-characteristics-187192.html.
Solve the following Cauchy problem
\displaystyle \frac{1}{2x}u_x + xu u_y + u^2 = 0,
subject to
\displaystyle u(x,x) = \frac{1}{x^2}, x > 0.
Attempt:
The characteristic equations are \displaystyle x_t = \frac{1}{2x}, y_t = xu, u_t = -u^2.
The initial conditions are x(0,s) = s, y(0,s) = s, u(0,s) = \frac{1}{s^2}.
The Jacobian is J = \begin{vmatrix}\frac{1}{2s} & \frac{1}{s} \\1 & 1\end{vmatrix} = - \frac{1}{2s} and hence we expect a unique solution when s \ne \pm \infty and s \ne 0. (Is this correct?)
Now solve the characteristic equations.
\displaystyle \frac{dx}{dt} = \frac{1}{2x}
2x dx = dt
x^2 = t + f_1(s).
Apply initial condition to get f_1(s) = s^2 and hence x = \sqrt{t + s^2}.
\displaystyle \frac{du}{dt} = -u^2
\frac{1}{u^2} du = - dt
u^{-1} = t + f_2(s)
u = \frac{1}{t + f_2(s)}.
Apply initial condition to get f_2(s) = s^2 and hence \displaystyle u = \frac{1}{t + s^2} = \frac{1}{x^2}. (Is this it for the question? Why is u independent of y? What have I done wrong?)
Substitute above x and y into characteristic equation y_t = xu and we get \displaystyle y = \frac{1}{\sqrt{t + s^2}}. Integrate over t and we get y = 2\sqrt{t + s^2} + f_3(s). Apply initial condition we get f_3(s) = -s and y = 2 \sqrt{t + s^2} - s.
From expressions of x and y obtained above we get
t = x^2 - s^2
\displaystyle t = \frac{1}{4}(y + s)^2 - s^2.
Therefore the characteristics is (y + s)^2 = 4 x^2. (Do I need this characteristics at all? What should I do with it?)
Is the above attempt correct?
You have for y:
<br /> \frac{dy}{dt}=\frac{1}{\sqrt{s^{2}+t}}\Rightarrow y(t)-s=\int_{0}^{t}\frac{du}{\sqrt{s^{2}+u}}<br />
This will give a different y than you have and it's where you have made a mistake I think. Once you have x and y in terms of s and t ten you should be able to get u in terms of x and y.
Why does \frac{dy}{dt} = \frac{1}{\sqrt{s^2 + t}} imply y(t) - s = \int^t_0 \frac{1}{\sqrt{s^2 + u}} du?
How do you get the -s on the LHS of the second equation?
Why is the integration on the RHS only from 0 to t? (I just realized that s > 0, is this related to the integral?)
What is the reason for substituting t with u and integrating from 0 to t?
Integrate both sides and use the initial conditions:
<br /> \int_{0}^{t}\frac{dy}{dt}dt=\int_{0}^{t}\frac{dr}{\sqrt{s^{2}+r}}=\left[ y\right]_{0}^{t}=y(t)-y(0)=y(t)-s<br />
Use a change of variables v=r+s^{2} and the integral becomes:
\int_{0}^{t}\frac{dr}{\sqrt{s^{2}+r}}=\int_{s^{2}}^{t+s^{2}}\frac{dv}{\sqrt{v}}<br />
I tried this and it turns out to be the same as what I got before.
\int^t_0 \frac{1}{\sqrt{s^2 + r}} dr = \int^{s^2+t}_{s^2} \frac{1}{\sqrt{v}} dv = \left[2 v^{\frac{1}{2}} \right]^{s^2+t}_{s^2} = 2\sqrt{s^2 + t} - 2s
y(t) = 2\sqrt{s^2 + t} - s
Then
s = 2x - y
t = x^2 - (2x - y)^2
and
u = \frac{1}{t + s^2} = \frac{1}{x^2 - (2x - y)^2 + (2x - y)^2} = \frac{1}{x^2}
Maybe this is the correct solution.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
