Understanding the Cauchy Stress Tensor for Beginners
The discussion centers on the Cauchy stress tensor, specifically the interpretation of its indices. The first index denotes the direction of the stress vector acting on a surface, while the second index indicates the normal direction of that surface. It is established that the Cauchy stress tensor is symmetric, meaning σ_xy equals σ_yx, which is crucial for avoiding infinite angular accelerations in an infinitesimal square element. The symmetry condition is noted as a special case that holds true when the Knudsen number approaches 1.
  • Understanding of tensor notation in continuum mechanics
  • Familiarity with the concept of stress in materials
  • Knowledge of the Knudsen number and its implications
  • Basic principles of mechanics related to torques and angular acceleration
  • Study the derivation and implications of the Cauchy stress tensor in continuum mechanics
  • Explore the relationship between stress components and material behavior under different loading conditions
  • Learn about the significance of the Knudsen number in fluid dynamics and its effect on stress tensor symmetry
  • Investigate applications of the Cauchy stress tensor in finite element analysis (FEA) software
This discussion is beneficial for students and professionals in mechanical engineering, materials science, and applied physics who are looking to deepen their understanding of stress analysis in materials and the mathematical framework of continuum mechanics.
member 392791
Hello,
I am not sure what the first indice in the cauchy stress tensor indicates
For example,
σ_xy means that the stress in the y direction, but does x mean the cross sectional area is normal to the x direction?
I can't see how σ_xy is dependent on σ_yx, they are perpendicular to each other
Who said anything about these stresses being dependent on one another?
My textbook said that the entire stress state can be determined with just 6 of the 9 components of the stress tensor. Is that to mean something different than there is a dependency? Or even they are equal?
The Cauchy stress tensor must be SYMMETRIC.
The reason for this is apparent when you consider the TORQUES about an infinitesemal square element.
Unless the stress tensor is symmetric, you'll get infinite angular accelerations of the square element.
The symmetry condition on the stress tensor explains why s_xy=s_yx and so on.
It should be mentioned, as is done in the Wikipedia article, that the symmetry of the Cauchy stress tensor is a special case as the Knudsen number goes to 1, so that symmetry is not required generally
Woopydalan said:
Hello,
For example,
Yes. There are three components of the stress vector acting on a plane oriented normal to the x direction. The (normal) component in the x direction is σxx. The (shear) component in the y direction is σxyyx. The (shear) component in the z direction is σxzzx.
  • · Replies 24 ·
