Buying Deuterated Chloroform: Silver Foil Benefits & TMS Considerations
  • Thread starter Thread starter Umabel
    Silver
Deuterated chloroform is often stabilized with silver foil to prevent the formation of chlorine-active species, such as DCl, which can arise from reactions with light and oxygen. This stabilization is particularly important for critical applications where purity is essential. The discussion also touches on the inclusion of TMS (tetramethylsilane) in the solvent, with a debate over the appropriate concentration. While 1% v/v TMS is common, it may be excessive for high-field NMR instruments, as it can produce a peak that overshadows most samples unless they are highly concentrated, a practice rooted in older low-field instrument usage.
Umabel
I was looking around to purchase some deuterated chloroform online. A few of the products offered include "stabalized with silver foil". What is the silver foil preventing the solvent from doing? FYI, this silver foil is probably inside the bottle.
One more thing, is there reason why you want to have 1% v/v TMS included in the solvent? I've seen 0.03% TMS, but 1% seems to be too many resonating protons for a 500 Mhz NMR instrument...
Chemistry news on Phys.org
1% is way too much for a high field instrument, IMO. Your TMS peak will be way too strong for most samples unless they are pretty concentrated, like in a C13 analysis. The 1% level has been used since low field CW instruments have been used and may be a throwback to those days.
Silver foil will scavenge any Cl- or chlorine active species from the bottle. For critical applications, it may help to remove any trace DCl. The chloroform solvent can react with light and oxygen to form phosgene and DCl.
Thanks.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
