Central force to 2-body problem: which values?
The discussion centers on determining the appropriate values for radius (r), velocity (v), and angle (α) in the context of the two-body problem, particularly when analyzing the trajectory of a reduced mass (μ). The polar equation for the orbit is established as r(θ) = p / (1 + ε * cos(θ - θ0)), where p is derived from angular momentum (L) and a gravitational constant (k). Participants emphasize that the trajectory can be calculated by selecting initial conditions for r, v, and α, and that the angular momentum of the reduced mass is crucial for determining its motion.
  • Understanding of the two-body problem in classical mechanics
  • Familiarity with polar coordinates and their application in physics
  • Knowledge of angular momentum and its calculation
  • Basic grasp of gravitational forces and their mathematical representation
  • Study the derivation of the polar equation for orbits in classical mechanics
  • Learn how to calculate angular momentum for a two-body system
  • Explore the use of Geogebra for simulating orbits and trajectories
  • Review the mathematical treatment of the two-body problem on Wikipedia
Students and professionals in physics, particularly those focused on classical mechanics, orbital dynamics, and mathematical modeling of physical systems.
Physics2.0
Hi, I'm new to this forum and I've got a question.
In all articles I've found about the two body problem, they first start off by writing the distances between the masses as one function r(t) and one function R(t) (which is just simple the position of the reference frame).
*note: i use initial position and speed to calculate the orbit equation*
Then they go to the central force problem and solve the equation of the orbit of a reduced mass (μ). This is a pretty complicated calculation, but eventually they all end up with the same polar equation:
r(θ) = \frac{p}{1+ε*cos(θ-θ0)}
where:
p = L^2 / k and L is the angular momentum which is the cross product of speed and position which is equal to L= r * v * sin(α) where r and v are absolute values (the length's of the vectors). k is some constant G*M in this case.
ε and θ0 can be expressed with the same values r, v and α, shown on this site http://upload.wikimedia.org/wikipedia/commons/d/de/Klassieke_Mechanica.pdf page 242 (it's in Dutch, sorry). I evuentually ended up making a 'geogebra applet' which calculates the path with the orbit equation of the reduced mass.
Now I want to go back to the two body problem, but I don't know which values r, v and α to use. Which values should I use??
Any help would be appreciated!
(if anybody is interested, I will post the geogebra file too)
Thanks in advance,
physics2.0
The values of r,v, α determine the condition of the moving body at some point of space; you can choose the system of polar coordinates in such a way that this point has θ =0.
You can choose any values you want. The equation then gives the trajectory of the body as a function r(θ); pair [r(θ),θ] are polar coordinates of the points on the trajectory.
I still don't know which values to use. To be clear: I solved the kepler problem; the values I used were quite easy to determine, because there is only one radius and one velocity.
So my question is: what is the position and the velocity of the 'imaginary' reduced mass of the two body problem.
How do I determine the trajectory of both masses?
Sorry for the repetition, my browser has some problems.
First of all thanks for the comments
Sorry I haven't said this, but I know that. The trajectory of the first mass is:
x1(t) = R(t) + \frac{m2}{m1+m2}*r(t)
And the same holds for the second mass (but m2 will change in m1)
Now I've learned that the time dependent radius r(t) cannot analytically be solved because the equation μr''=f(r)+ L^2/(μr^3 ) cannot be solved analytically.
However when converting r as a function of \theta you can get r(\theta). This is the formula I posted in my first post.
From this point on I'm stuck. I don't know which values p,e and theta0 to use. Actually this boils down to two things I don't know:
What is the speed of the reduced mass? Or what is the angular momentum of the reduced mass?
If I know its speed I know its angular momentum because r0 is the distance between the to masse's at t=0; But maybe the angular momentum of the reduced mass is the sum of the angular momenta of the other two masses?
Please help me out.
What exactly do you want to find out?
It seems you want to find the mutual distance of two bodies as a function of the angle in polar coordinates. Let's say the observer is on the body 2 and observes the body 1, as it circles around 2.
Let R be vector of 1 with respect to 2:
<br /> \mathbf R =\mathbf r_1 - \mathbf r_2<br />
This vector changes in time according to
<br /> \ddot{\mathbf R} = - \frac{G(m_1+m_2)}{R^3}\mathbf R.~~~(*)<br />
This should be easy to see from the original equations.
This equation is the same as for anybody of any mass orbiting around fixed centre of mass m_1+m_2. So the trajectory and function R(θ) will be the same. The vector R circumscribes ellipse, and its magnitude will is given by
<br /> R(\theta) = \frac{p}{1+\epsilon \cos (\theta-\theta_0)}.~~~(\text{T})<br />
You can see that \theta_0 is the angle for which the radius vector has the smallest length - the body 1 is at perigeum. Because there are no other requirements on the orientation of the polar system of coordinates, we can orient it in any way. Particularly convenient choice is such that the perigeum is at \theta = 0, i.e. \theta_0 = 0.
The quantities p,\epsilon in the above equation are connected to angular momentum and total energy of the body moving around the fixed centre. In order to find them, imagine you have a small planet that starts to move around fixed center according to *, with position R and velocity \dot {\mathbf R} - which are given by the initial conditions. Find its energy and angular momentum and use the above mentioned formulae to find its p and \epsilon.
These are obtained in the course of derivation of the equation of trajectory (T), or you can find them on Wikipedia or in any book on classical mechanics.
  • · Replies 30 ·
  • · Replies 40 ·
  • · Replies 22 ·
