Calculating Center of Gravity and Force for a Flagstaff
In summary, the problem involves determining the center of gravity of a flagstaff with a length of 10m by using a vertical force F at the thin end and a horizontal force 4F at the thick end to keep it in horizontal balance. The task is to find the center of gravity and the force F when the mass of the flagstaff is 250kg. Through taking moments about the wall and using the formula for moment about a point, the total moment about the top of the wall can be determined and equated to 0, allowing for the calculation of x, the distance from the wall to the center of gravity. By setting the two resulting equations equal to each other and solving for x, the center of gravity can be determined
Newton86
59
This is the case:
We going to decide the centre of gravity to a flagstaff with length 10 m
We saved up the flagg staff in the thick end. We then need to use a vertical force F in the thin end to keep the flagstaff in horizontal balance. We then saves up the flagstaff in the thick end. Then we need to use a horizontal force on 4F in the thick end too keep the flagstaff in horizontal balance.
i) Count out where the centre of gravity to the flagstaff is.
ii) Count out the force F when the mass of the flagstaff is 250 kg.
Can anyone get me started ?
I have no idea what this means:
Hi Newton86! :smile:
I'm confused. :confused:
Can you give us the question in the original language … there'll probably be a lot of people on the forum who'll understand it! :smile:
Ok:)
bildr.no/view/190755
Not sure i quite understand it myself :confused:
ah … got it … !
We rest the thick end of the flagpole on something (a wall, maybe), and we weigh the other end, result F.
Then we rest the thin end of the flagpole on something, and we weigh the other end, result 4F.
Hint: take moments about the wall.:smile:
one moore hint ? :P
ok … one more hint …
there are three forces acting on the flagpole …
draw a diagram …
draw a force N where it rests on the wall, its weight W vertically through the centre of gravity, and the force F (or 4F) vertically at the other end.
You don't know what N is, and you don't want to know, so you eliminate N by taking moments about the wall.
Have a go … ! :smile:
190817.jpe
Like this ? Is there moore forces ?
(btw, it's "more", not "moore")
Nooo …
That's a really bad diagram … what are those two vertical lines on either side? … and you should have the arrows starting (or ending) at the point of application of the force … and you haven't marked the length of the flagpole or the postion of the centre of gravity.
And you need two diagrams … one with the wall at the thick end and F at the thin end, the other with the wall at the thin end and 4F at the thick end.
It is very very important that you get used to making clear accurate diagrams. If you don't, you may make mistakes, or even not be able to answer the question at all. :redface:
ok … draw one of the diagrams, and then take moments about the wall. :smile:
hmm Not sure i understand it quite but I tryed again.
190891.jpe
Do I know where the center of the gravity is ?
I don't get this Iv searched for other examples too but no one uses forces =|
Now that's a much better diagram! :smile:
No … but that's what the question asks you to find … so the standard trick is to give it a name, like x, and put x in the diagram.
ok … now what, in terms of W and x, is the moment of the weight about the wall?
and what is the moment of the F force about the wall? :smile:
I would like to know that. I don't find any formulas ( used all day ) :cry:
How can a noob get such a task :mad:
cheer up! :smile:
Moment about a point = force times distance (that's the distance from the point to the line of the force).
In this case, the distances of the three forces from the wall are 0, x, and 10 in the first diagram, and … ? in the second diagram.
So the total moment about the top of the wall is 0 + x.W - 10.F in the first diagram, and … ? in the second diagram.
When there is no turning, the total moment about any point must be 0.
(is any of this familiar?)
So … ? :smile:
Ah This looks familiar too vectors. :smile:
In this case, the distances of the three forces from the wall are 0, x, and 10 in the first diagram, and the same distance in 0, x, 10 ? in the second diagram.
So the total moment about the top of the wall is 0 + x.W - 10.F in the first diagram, and 0 + x.W - 10.4F ( -40F? )? in the second diagram.
( 0, x, -10 )( 0,x,-40) ?
wild guess is the the center of gravity is 7,07m from the thin end
oooh :cry: … you didn't put x into your diagrams, did you?
If you had, you'd have seen that it's 10 - x in the second diagram … right?
That's why good diagrams are so important!
So the answer is … ? :smile:
ye I was unsure about that. But I don't see how I can use this too find the center of gravity
and What about the other diagram was it wrong too?
Your first formula was right.
Your second formula would have been right, except that it shouldn't have had x.
Get it right, put the two formulas equal to zero (you do understand why, don't you?), and then solve the two equations! :smile:
Could you set them up correctly ?:redface: maybe I will understand a bit moore caus I am a bit confused on this :confused:
No!
Show us what you can do … then we can see where the problem is! :smile:
Ok I am thinking (0,x,10)(10-x,0) =0
But that doesn't even mean anything! :cry:
(they're not vectors … and even if they were, how would you combine a 3-term vector with a 3-term one? :confused: )
Go back to:
Newton86 said:
So the total moment about the top of the wall is 0 + x.W - 10.F in the first diagram …
Now, (as I told you) that was right!.
So the total moment about the wall (for the first diagram) is x.W - 10.F.
And there is no turning, so this has to be zero (do you understand why that is … you haven't said … ?), and so:
x.W = 10.F.​
Now do the same thing for the second diagram … you should get a similar equation … what is it … ? :smile:
no I can't say I know why it has to be equal to zero.:shy:
But momentum was force times length from the point to the force so I think the second diagram then must be:
x.W = 10*4 = 40.F ?
ok … you need to understand moments first, or everything will be mumbo-jumbo.
Read this (torque and moment are the same): http://en.wikipedia.org/wiki/Torque.
Then tell me if you understand why the moments have to add to zero. :smile:
Is it caus if it had not been zero it would start to rotate ?
And it has to be = 0 to be in balance
Yes, that's right!
It's the circular form of Newton's second law …
moment of force = mass times circular (or perpendicular) acceleration. :smile:
If there's no turning (so either static or moving in a straight line), then, as you say, the sum of the moments of the force must be zero.
It's very useful when (as here) the usual linear form of Newton's second law doesn't give quite enough information!
Newton86 said:
… I think the second diagram then must be:
x.W = 10*4 = 40.F ?
hmm … I don't know you got two equals signs in that … :confused:
There should be a (10 - x) in there somewhere, shouldn't there? :smile:
Im thinking..
Im struggling with this task =|1: 0 + xW -10F that's right
but the way I see the 2 one is either
2: 0 +xW-40F or
2: -10F + xW+-40F
Newton86 said:
2: 0 +xW-40F or
2: -10F + xW+-40F
erm … what happened to the 10 - x … and where did that 10F come from? :confused:
  • #31
I don't know how to explain I don't think I understand some basics here.
why is the 1 one 0 + wX and the second one 10 - x ?
Is there another way to solve it ? =s
http://www2.ucdsb.on.ca/tiss/stretton/PhysicsFilm/ForceTorque/sld011.html
Found this. Could this problem be solved in a similar way ?
  • #32
Newton86 said:
Iwhy is the 1 one 0 + wX and the second one 10 - x ?
Because first the cog is distance x from the wall,
but when you turn the flagpole round, the cog is distance (10 - x) from the wall! :smile:
So the second equation has (10 - x)W where the first equation has xW. smile:
(and no, that picture doesn't help, because it shows two known forces at the same time, and this problem only has one at a time … nice website though! :smile:)
  • #33
That make sense :)
1: 0 + xW -10F
2: (10-x)W + 40F then ?
  • #34
Newton86 said:
… then ?
erm … to find x, you eliminate F.
no? :smile:
  • #35
So the equations are correct now ?
Its Wx we need to find ? Do i solve it by using both equations ? never been good at equations either.
