Centripetal motion, find radius - which solution is correct?
The discussion revolves around calculating the radius of Saturn's orbit using two methods, yielding different results. The first method uses the orbital period and speed, resulting in a radius of approximately 9.24 x 10^11 meters. The second method applies centripetal force equating to gravitational force, giving a radius of about 1.41 x 10^12 meters. The discrepancy arises from an incorrect orbital period provided in the problem, which should be 29 years instead of 19. Both methods are valid, but the error in the orbital period affects the calculations.
Tyrannosaurus_
The planet Saturn will orbit the Sun every 19 Earth years (= 599 184 000 seconds). Assume Saturn travels on a circular orbit with a speed of 9 690m/s. What is the radius of the orbit of Saturn?
I can solve this in two different ways, and get two different values. Which is the correct approach, & why?
2. Homework Equations & attempt at solution.
T = (2πr)/V - that is, period is 2π*radius over speed.,
so, r = (T*V)/2π
so, radius = 9.24 x 1011m
However, if, the centripetal forces equals the universal law of gravitation, that is,
Fc = Fg
(m*v2)/r = (Gm1m2)/r2
r = (G*msun)/v2
r = [(6.67x10-11)(1.99x1030kg)]/(9690m/s2)
r = 1.41 x 1012m
So, why the difference? What applies, and what doesn't apply and why?
Thanks!
so, r = (T*V)/2π
Fc = Fg
r = (G*msun)/v2
r = 1.41 x 1012m
Thanks!
Both of your methods are correct, but the problem maker gave wrong orbital period. It is 29 years, instead of 19.
Likes Tyrannosaurus_
Thanks so much! I was going crazy!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
