Calculate Centroid of Hemispherical Dome w/ Top Removed
  • Thread starter Thread starter jiboom
    Centroid
The discussion focuses on calculating the volume of a concrete pile and finding the centroid of a hemispherical dome with the top removed. For the pile, the volume is identified as that of a frustum, using the base radius of 2000 mm, top radius of 1000 mm, and height of 2000 mm. The centroid of the hemispherical dome can be determined using integration, specifically through the washer method, which involves slicing the volume into discs. Participants discuss setting the origin at the sphere's center and applying integration to find the volume and the moment about the y-axis. The conversation emphasizes the need for understanding the integration process to accurately find the centroid's position.
jiboom
Pile foundations are the part of a structure used to carry and transfer the load of the structure to the bearing ground located at some depth below ground surface.
A concrete pile for a domestic dwelling has a radius of 1000 mm at its base, and 2000 mm at the top. It is 2000 mm deep and the sides slope uniformly.
Find the volume of concrete needed to form this pile.
A plinth is formed in the shape of a hemispherical dome, radius 4 m, with its top 1 m removed. Using integration, find the position of the plinth’s centroid along its axis of symmetry.
i think i just need volume of a frustrum for first part,with base radius 2000 and top radius 1000 and height 2000??
s0
2pi[4+2+1]/3= 14pi/3
how do i go about the second part? what do i need to ingrate for this shape?
Suppose you set the origin at the sphere's centre and take the x-axis to be the axis of symmetry of the plinth. Can you apply the 'washer' method to find the volume? Finding the moment about the y-axis is very similar. Do you know a formula for the x coordinate of the mass centre?
not heard of the washer method. i know the formula for x bar for a hemisphere but the question wants it from integration
The washer method just slices a volume of revolution into discs perpendicular to the axis. Write down the expression for the area of one such disc, thickness dx, and integrate. Thst gives the volume. Repeat the process with an extra factor x to get the moment of the disc element and integrate again.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
