Chain Dynamics: Solving for Maximum Length
  • Thread starter Thread starter tokkii
    Chain
The problem involves a chain of mass per unit length that is coiled on the floor and subjected to a constant force. Participants are tasked with determining various properties of the chain's motion as it is pulled, specifically focusing on the maximum length it can reach under the applied force.
  • Participants discuss the relationship between force, mass, and acceleration, questioning whether the chain's mass remains constant as it extends. They explore the implications of the velocity of the chain at maximum length and the total energy involved in the system.
The discussion is active, with participants raising questions about the definitions of variables such as length and height, and the implications of a constant force on the chain's motion. There is a recognition of the complexity involved in understanding the dynamics of the chain as it reaches its maximum length.
Participants note confusion regarding the definitions of variables and the physical meaning of maximum height in relation to the chain's motion. There is an acknowledgment that the mass of the chain increases as its length increases, which may affect the dynamics being analyzed.
tokkii
Hey good people, I am new here and i found that you help people, i hope you can help me with this
ive been triyng to solve this for a while but with no luck
1. Homework Statement
A chain of mass m0 per unit length is loosely coiled on the floor. If one of the end is subjected to a constant force P, when y = 0 , determine followings when P = 10N and m0 = 0.2kg / m
(a) Determine the maximum value of chain length ymax
(b) Determine the velocity of the chain as a function of y while 0 ≤ y ≤ ymax .
(c) Determine the acceleration of the chain as a function of y while 0 ≤ y ≤ ymax .
(d) Plot velocity and acceleration of hook chain as a function as a function y in all the cases using MATLAB while 0 ≤ y ≤ ymax .
Im only interested in Part (a) .. i can do the rest by myself.
2. Homework Equations
P=mv, p=momentum , m=mass , v= velocity
u=m/y, u=linear density , m=mass , y= length
i started with the momentum equation i derive it using the chain rule ... i worked it out i end up with deferential equation
F=2*u*dy*(d^2y/dt^2)
now I am stuck at this point, I am not sure if it correct or not ... is it possible to solve it without using deferential equation ?
What is the velocity of the chain at ##y_\text{max}##? Why?
What is the total energy of the chain? Can you relate that with ##P##?
Vf=Vi+at since Vi=0 >>> Vf=at ? or v=ds/dt
KEi + PEi + Wext = KEf + PEf
initially it was at rest v=0 and height was 0 that gives us
Wext = KEf + PEf => W = 0.5mv^2+mghi don't have enough knowns to use this ...
What does ##y## mean in #1? And what is ##y_\text{max}##? Why does it have the "max" label?
And what is this ##h## that you used in #3?
voko said:
What does yy mean in #1? And what is ymaxy_\text{max}? Why does it have the "max" label?
in this case y is the length, the question stated that initially it was at elevation of 0 so length will be 0, y max is the maximum length the chain will reach up the ground ... here is where my confusion start, I am not sure if the chain will stop going up at any point, so from this i concluded the answer will be an equation with respect to time
voko said:
And what is this hh that you used in #3?
h is the length
So, is this "length" really the "height"?
What is the velocity of the chain when it reaches the max height?
tokkii said:
h is the length
So is it the same as ##y##?
the height of a point at the tip of the chain off the ground is the length of the chain,
the force is constant velocity will keep increasing
voko said:
So is it the same as yy?
yes
If the velocity is increasing, how can there be a maximum height?
i asked myself the same thing, but that's what the question asks .. it beats me really
So perhaps the velocity is not always increasing? What makes you think it must be ever increasing in the first place?
Since F=ma , if the force is constant and it is as stated in the problem, then there is constant acceleration and therefore changing velocity according to a=dv/dt
If ##m## is constant. Is it constant?
voko said:
If mm is constant. Is it constant?
hmmm ... no, m increase as length increase
  • · Replies 30 ·
