Challenge 8: Sub-Gaussian Variables
  • Context: Graduate
  • Thread starter Thread starter Office_Shredder
    Challenge Variables
9 replies · 5K views
A random variable X is called sub-gaussian if
[tex]P( |X| > t) \leq 2e^{-K t^2}[/tex]
for some constant K. Equivalently, the probability density p(x) is sub-gaussian if
[tex]\int_{-t}^{t} p(x) dx \geq 1 - 2 e^{-Kt^2}.[/tex]
The challenge: Prove that the standard normal distribution (with mean 0 and variance 1) is sub-gaussian.
I haven't found a solution yet, but here's a method that might be useful.
The standard normal distribution has the following probability density function:
$$p(x) = \frac{1}{\sqrt{2\pi}} e^{-x^2/2}$$
Therefore we wish to prove that there exists some ##K## such that
$$\int_{-\infty}^{\infty} r_t(x) p(x) dx \geq 1 - 2e^{-Kt^2}$$
where
$$r_t(x) = \begin{cases}
1 & \text{ if }|x| < t \\
0 & \text{ if }|x| > t\\
\end{cases}$$
Note that in general, the integral of a function is equal to its Fourier transform evaluated at zero:
$$\int_{-\infty}^{\infty}f(x) dx = \left. \int_{-\infty}^{\infty} f(x) e^{-2\pi i u x} dx \right|_{u = 0} = \hat{f}(0)$$
where ##\hat{f}## is the Fourier transform of ##f##:
$$\hat{f}(u) = \int_{-\infty}^{\infty}f(x) e^{-2\pi i u x} dx$$
We may therefore express our desired integral (let's call it ##I##) in terms of Fourier transforms:
$$I = \int_{-\infty}^{\infty} r_t(x) p(x) dx = \widehat{r_t p}(0)$$
where ##\widehat{r_t p}## is the Fourier transform of the product ##r_t p##. It's easy to show that the Fourier transform of a product is equal to the convolution of the Fourier transforms of the factors:
$$\widehat{r_t p}(u) = \int_{-\infty}^{\infty} \widehat{r_t}(u-v)\widehat{p}(v) dv$$
Evaluating at ##u = 0##, we get
$$I = \widehat{r_t p}(0) = \int_{-\infty}^{\infty} \widehat{r_t}(-v) \widehat{p}(v) dv$$
Let us now compute ##\widehat{r_t}## and ##\widehat{p}##. Starting with the definition of the Fourier transform, we obtain
$$\begin{align}
\widehat{r_t}(v) &= \int_{-\infty}^{\infty} r_t(x) e^{-2\pi i v x} dx \\
&= \int_{-t}^{t} e^{-2\pi i v x} dx \\
&= \int_{-t}^{t} \cos(2\pi v x) dx \\
&= 2 \int_{0}^{t} \cos(2\pi v x) dx \\
&= \left. 2 \frac{\sin(2\pi v x)}{2\pi v} \right|_{x = 0}^{x = t} \\
&= 2 \frac{\sin(2 \pi v t)}{2\pi v} \\
&= \frac{\sin(2\pi v t)}{\pi v}\\
\end{align}$$
Note that the result is an even function of ##v##, i.e., ##\widehat{r_t}(-v) = \widehat{r_t}(v)##, so we can simplify our expression for ##I## to
$$I = \int_{-\infty}^{\infty} \widehat{r_t}(v) \widehat{p}(v) dv$$
Next we calculate ##\hat{p}##, again starting from the definition. We have
$$\begin{align}
\hat{p}(v) &= \int_{-\infty}^{\infty} p(x) e^{-2 \pi i v x} dx \\
&= \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} e^{-x^2/2}e^{-2\pi i v x} dx\\
&= \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} \exp\left(-\frac{1}{2} (x^2 + 4\pi i v x)\right)dx \\
&= \exp\left(-\frac{1}{2} 4 \pi^2 v^2\right) \frac{1}{\sqrt{2\pi}} \int_{-\infty}^{\infty} \exp\left(-\frac{1}{2} (x + 2\pi i v)^2\right) dx \\
&= \exp\left(-\frac{1}{2} 4 \pi^2 v^2\right) \frac{1}{\sqrt{2\pi}} \cdot \sqrt{2\pi} \\
&= \exp(-2\pi^2 v^2)
\end{align}$$
Plugging the expressions for ##\widehat{r_t}## and ##\hat{p}## into our integral, we obtain
$$I = \int_{-\infty}^{\infty}\widehat{r_t}(v) \widehat{p}(v) dv =
\int_{-\infty}^{\infty} \frac{\sin(2\pi v t)}{\pi v} \exp(-2\pi^2 v^2) dv$$
Now if I can find the right lower bound for the integrand as a function of ##v## and ##t##, the result might follow. Or I could be barking up the wrong tree.
Intuitively, as ##t## increases, ##\sin(2\pi v t)/(\pi v)## becomes a taller and skinnier function centered at ##v = 0##, although with tails that decay on the order of ##1/v##, so the oscillations are important! Most of the value of ##I## is hopefully determined by the part spanned by the "main peak" of ##\sin(2\pi v t)/(\pi v)##, which is the part for which ##|v| < 1/(2t)##.
I think it's true that
$$I > \int_{-1/t}^{1/t} \frac{\sin(2\pi v t)}{\pi v} \exp(-2\pi^2 v^2) dv$$
because outside the interval ##[-1/t, 1/t]## you could approximate the integrand as an alternating series whose first term is positive.
Let's try this.
We wish to prove that ##\displaystyle 1\leq\frac{\sqrt{2}}{\sqrt{\pi}}\int\limits_{[0,t]}e^{-\frac{x^2}{2}}\mathrm{d}x+2e^{-kt^2}=f(t)##.
Attempt 1:
Expanding by power series, we get $$\frac{\sqrt{2}}{\sqrt{\pi}}\int\limits_{[0,t]}e^{-\frac{x^2}{2}}\mathrm{d}x=\frac{\sqrt{2}}{\sqrt{\pi}}\sum_{0\leq n}\frac{(-1)^n t^{2n+1}}{2^n(2n+1)n!}.$$
For ##2e^{-kt^2}##, we expand and get ##\displaystyle 2e^{-kt^2}=2\sum_{m\geq 0}\frac{(-1)^mk^mt^{2m}}{m!}##.
Let ##k=\frac{1}{2}## for ease of notation. After a myriad of simplifications and a couple series manipulations which I am not going to LaTeX out, we just need to prove $$1\leq 2\sum_{n\geq 0}(-1)^n\frac{t^{2n}(t+\sqrt{2\pi}(2n+1))}{\sqrt{2\pi}2^n(2n+1)n!}.$$
By properties of alternating series, I'm pretty sure that one can show the RHS is always greater than 1.
Attempt 2:
Note that $$\frac{d}{dt}\left(\frac{\sqrt{2}}{\sqrt{\pi}}\int\limits_{[0,t]}e^{-\frac{x^2}{2}}\mathrm{d}x+2e^{-kt^2}\right)=\sqrt{\frac{2}{\pi}}e^{-\frac{1}{2}t^2}-4kte^{-kt^2}=e^{-\frac{1}{2}t^2}(\sqrt{\frac{2}{\pi}}-2t).$$ Letting ##k=1/2## again, for convenience. Then, we note that ##max(f)=f\left(\sqrt{\frac{1}{2\pi}}\right)>1##. Since ##f## is [strike]increasing[/strike] (clearly decreasing with an asymptote at 1) for all ##t>\sqrt{\frac{1}{2\pi}}## and ##f(t)>1## for all ##0\leq t\leq \sqrt{\frac{1}{2\pi}}##, the result follows.
Not sure if either of these is right. They were pretty ugly.
Edit: Ignore the second part. I clearly did something horribly wrong with the derivatives. >_>
I guess we just consider t≥0?
For t=0, it is trivial (left side 1/2, right side 1), consider t>0 now.
We want to show
$$\int_{-t}^{t} p(x) dx \geq 1 - 2 e^{-Kt^2}$$
As the normal distribution is symmetric, this can be written as
$$1-2\int_{t}^{\infty} p(x) dx \geq 1 - 2 e^{-Kt^2}$$
or
$$\int_{t}^{\infty} p(x) dx \leq e^{-Kt^2}$$
As a plot and with the example K=1/2, this means the red line has to be above the blue line in the WolframAlpha plot
(if the url does not work, the query: "plot int(1/sqrt(2pi)*exp(-y^2/2), y from x to infinity), e^(-x^2/2)")[/size]
Let's find an upper bound for the integral. As the integrand is monotonically decreasing,
$$\int_{t}^{\infty} p(x) dx \\
\leq \sum_{i=0}^\infty p(t+i) \\
= \frac{1}{\sqrt{2\pi}} \sum_{i=0}^\infty \exp\left(\frac{-(t+i)^2}{2}\right) \\
< \frac{1}{\sqrt{2\pi}} \sum_{i=0}^\infty \exp\left(\frac{-t^2-2ti}{2}\right) \\
= \frac{1}{\sqrt{2\pi}} \exp(-t^2/2) \sum_{i=0}^\infty \left(e^{-t}\right)^i
As t>0, exp(-t)<1 so we can evaluate the sum.
$$ = \frac{1}{\sqrt{2\pi}} \exp(-t^2/2) \frac{1}{1-e^{-t}}$$
Let's fix ##K=\frac{1}{2}##. We have to show that
$$\frac{1}{\sqrt{2\pi}} \exp(-t^2/2) \frac{1}{1-e^{-t}} \leq e^{-t^2/2}$$
This is satisfied if
$$\sqrt{2 \pi} (1-e^{-t}) \geq 1$$
where equality gives approximately t ≈ 0.51. Therefore, the inequality is satisfied for t≥1.
It is left to show the inequality for 0<t<1. In this interval, the LHS is ≤ 0.5, but ##e^{-t^2/2} > e^{-1/2} \approx 0.607 > 0.5.
As a result, with K=1/2 the inequality is satisfied everywhere and the standard normal distribution is sub-gaussian.
Mandelbroth said:
Let's try this.
Attempt 1:
That seems like it would be hard - if t is sufficiently large the first bunch of terms will be increasing in magnitude (as they will have higher powers of t).
mfb, that's a really nice solution, I like the idea of bounding the integral with a Riemann sum. k=1/2 is actually the best bound that I know of, but your proof is the first one that makes me think that it is genuinely tight as opposed to just convenient (since the sum should be a really good estimate if t is large).
Any alternate proofs out there people can come up with?
Proof:
{\bf \geq} \sum_{i=1}^\infty p(t+i) \\
= \frac{1}{\sqrt{2\pi}} \sum_{i=1}^\infty \exp\left(\frac{-(t+i)^2}{2}\right) \\
> \frac{1}{\sqrt{2\pi}} \exp(-\frac{(t+1)^2}{2})$$
Where the last expression is simply the first term of the sum.
Let's look at the inequality:
$$\frac{1}{\sqrt{2\pi}} \exp(-\frac{(t+1)^2}{2}) < e^{-K t^2}$$
This can be solved for K:
$$c+(t+1)^2 > 2Kt^2$$
Where ##c=\log(2 \pi)## is constant.
$$K< \frac{c+(t+1)^2}{2t^2} = \frac{1}{2} + \frac{1}{t} + \frac{1+c}{2t^2}$$
K cannot be larger than 1/2, or the inequality gets violated at some point.
mfb said:
Proof:
That's...awesome. In the series method I used, ##k=\frac{1}{2}## was actually what I considered an aesthetic choice. I chose it because it made the computations simple and lots of things canceled to give something I knew would converge. That's pretty fantastic, when you think about how all of it connects. :approve:
One part gives a nice sum, the other part gives the error function:
$$ \sum_{n\geq 0}(-1)^n\frac{t^{2n}(t+\sqrt{2\pi}(2n+1))}{\sqrt{2\pi}2^n(2n+1)n!} \\
= \sum_{n\geq 0}(-1)^n\frac{t^{2n}(\sqrt{2\pi}(2n+1))}{\sqrt{2\pi}2^n(2n+1)n!} + \sum_{n\geq 0}(-1)^n\frac{t^{2n}t}{\sqrt{2\pi}2^n(2n+1)n!} \\
= \sum_{n\geq 0}(-1)^n\frac{t^{2n}}{2^nn!} + \frac{1}{\sqrt{2\pi}}\sum_{n\geq 0}(-1)^n\frac{t^{2n+1}}{2^n(2n+1)n!} \\
= \sum_{n\geq 0}\frac{(-t^2/2)^n}{n!} + \frac{1}{\sqrt{2\pi}}\sum_{n\geq 0}(-1)^n\frac{t^{2n+1}}{2^n(2n+1)n!} \\
= \exp\left(-\frac{t^2}{2}\right) + \frac{1}{\sqrt{2\pi}}\sum_{n\geq 0}(-1)^n\frac{t^{2n+1}}{2^n(2n+1)n!}$$
Let's focus on the second part:
$$\frac{1}{\sqrt{2\pi}}\sum_{n\geq 0}(-1)^n\frac{t^{2n+1}}{2^n(2n+1)n!} \\
= \int dt \frac{d}{dt} \frac{1}{\sqrt{2\pi}}\sum_{n\geq 0}(-1)^n\frac{t^{2n+1}}{2^n(2n+1)n!} \\
= \frac{1}{\sqrt{2\pi}} \int dt \sum_{n\geq 0}(-1)^n\frac{t^{2n}}{2^n n!} \\
= \frac{1}{\sqrt{2\pi}} \int dt \exp\left(\frac{-t^2}{2}\right)$$
Now we have to get the integration constant right: For t=0, the expression is 0.
$$ = \frac{1}{\sqrt{2\pi}} \int_0^t dt' \exp\left(\frac{-t'^2}{2}\right)$$
So now we are comparing a gaussian with the error function again. I think this went in a circle...
We have to prove that$$1 \leq 2 \exp\left(-\frac{t^2}{2}\right) + \frac{2}{\sqrt{2\pi}} \int_0^t dt' \exp\left(\frac{-t'^2}{2}\right)$$
Which is equivalent to (using the symmetry of the integral)
$$1 - 2 \exp\left(-\frac{t^2}{2}\right) \leq \frac{1}{\sqrt{2\pi}} \int_{-t}^t dt' \exp\left(\frac{-t'^2}{2}\right)$$
And that is exactly the initial problem statement. Okay, bad direction. Well now we have that in TeX.
I'm literally crying with laughter right now. That was hilarious. :smile::smile::smile:
