HZXAHNLfzjSr
- 10
The Earth may be assumed to be an isolated sphere of radius 6.4 × 103 km with its mass of 6.0 × 1024 kg concentrated at its centre. An object is projected vertically from the surface of the Earth so that it reaches an altitude of 1.3 × 104km.
Calculate, for this object:
(i) the change in gravitational potential
(ii) the speed of projection from the Earth’s surface, assuming air resistance is
negligible.
My Attempt
i) I applied the formula
φ = - GM/radius of Earth + altitude of object
= GM (1/radius of Earth - 1/altitude of object)
= 3.17 x 10^10 J/kg
Don't know what I'm doing wrong here, this is not the correct answer.
The marking scheme of this past paper states the following solution:
change = 6.67 x 10^-11 x 6.0 x 10^24 x ({6.4 x 10^6}-1 - {1.94 x 10^7}-1)
change = 4.19 x 107 J/kg
I am not sure how they calculated the bold part?
ii)
I used the Escape Velocity Formula as follows:
Vesc = squareroot{[2GM/r]} or squareroot[2gr]
Vesc = 3.54 x 10^5
Again this is not correct answer. So when do we use this escape velocity formula exactly if not in this case?
Again the marking scheme has the following suggested solution:
½mv2 = mdeltaφ
v2 = 2 x 4.19 x 107 = 8.38 x 107
v = 9150 m s-1
Here I'd like to ask, how come we have equated gravitational potential and kinetic energy? Aren't they two different things?
Thanks in advance!
negligible.
My Attempt
= 3.17 x 10^10 J/kg
ii)
Vesc = 3.54 x 10^5
½mv2 = mdeltaφ
v = 9150 m s-1
Thanks in advance!
