Change in Momentum using Vectors
A force F = (2ti + 3t^2j) N acts on an object in the xy plane, and the task is to find the change in momentum from t=0 to t=2. The magnitude of the force is derived as (4t^2 + 9t^4)^(1/2), leading to the expression for change in momentum as delta p = 2t(4 + 9t^2)^(1/2). To find the total change in momentum, integration of the force over the specified time interval is necessary due to its time-dependent nature. The integration yields a change in momentum of 4i + 8j. Understanding this process is linked to Newton's second law, which relates force and momentum change.
Priyadarshini
A force F = (2ti + 3t^2j) N acts on an object moving in the xy plane. Find the magnitude of change in momentum of the object in time interval t=0 to t=2
(The bold ones are vectors)
Ft=change in momentum
magnitude of F = (4t^2 + 9t^4)^(1/2)
taking t^2 common:
t(4+9t^2)^(1/2)
Ft=delta p
so, delta p = 2t(4 + 9t^2 ) ^ (1/2)
But the answer doesn't have ts in it.
Have you learned calculus? The force is time-dependent, so you will have to perform an integration to find out the total change in momentum over the time interval.
I have learned it. But have never actually used it in physics.
So I integrate F?
Like:
Integration of 2ti+3t^2 j
is t^2i + t^3j
with the limits 0 and 2
Then,
4i + 8j is the change in p
Yes. You can understand the integration process by looking at Newton's second law, which states that \vec{F} = \frac{d\vec{p}}{dt}, and so this immediately results in \Delta p = \int_{t_0}^{t_f}\vec{F} dt
Thank you!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
