Change In Momentum With No Loss Of Ke
A ball with an initial momentum of +4.0 kg*m/s bounces back from a wall without losing kinetic energy, leading to confusion about momentum conservation. While kinetic energy is conserved in this scenario, momentum is also conserved in collisions involving multiple objects. The change in momentum occurs due to the reversal of direction, not a loss of energy. The discussion highlights that momentum can change in magnitude or direction, emphasizing that even with energy conservation, momentum can still vary. Understanding these principles clarifies the relationship between momentum and kinetic energy in collisions.
studentmom
A ball with original momentum of +4.0 kg*m/s hits a wall and bounces straight back without losing any kinetic energy. The change in momentum of the ball is?
p (momentum) = mv
Impulse = change in p/change in t
I thought that if the KE was conserved, then momentum had to be conserved to, so needless to say, I am confused. Any help would be appreciated!
just bumping up ... any ideas??
You are correct that momentum is conserved. In fact, it is conserved even if the energy is not. Every collision involves more than one object. In this case there are two objects. Conservation of momentum means that the sum of the momenta of the two objects is conserved, not that the momentum of a single object is conserved.
If you look at the definitions of momentum and kinetic energy you will see that an object can acquire momentum while gaining almost no kinetic energy. (How can this be?) Strictly speaking the ball cannot retain all of its energy when bouncing off the wall, but the amount that it must lose is such a small fraction of what it had to begin with that for all practical purposes it has not lost any.
Hint: Momentum is a vector. Momentum can change by changing either the magnitude or the direction, or both. If the momentum changes from (just for example) 10 kg-m/sec to the left to 10 kg-m/sec to the right, what is the change in momentum?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
