Changing iPhone Battery: Tips for DIY NiMH Replacement | 1810 mAh to 300 mAh
  • Thread starter Thread starter Infinityze
    Battery Iphone
Replacing an iPhone battery with a NiMH battery is not feasible due to significant voltage and compatibility issues. iPhone batteries are non-removable and designed for specific charge profiles, which NiMH batteries do not meet, risking damage to the device. Using a 1.2V NiMH battery will not provide sufficient power, as the iPhone requires a higher voltage. Additionally, fitting multiple NiMH batteries into the iPhone is impractical, and the existing electronics are calibrated for Li-ion batteries, which could lead to malfunction. Overall, attempting this DIY project is highly discouraged due to the potential for irreversible damage to the phone.
Infinityze
So for a DIY project I'm doing, I want to replace my iPhone battery (about 1810 mAh, 3.7V) with a NiMH battery (300 mAh, 1.2V) but I need help getting past some of the problems (and maybe more).
First of all. I've read that iPhone batteries are non-removable, is this true?
I've also read that I will require more circuitry to do this, but I'm not sure what.
Will the battery still run on 1.2V? If not, do I have to do something like put 3 of them in series?
Are there any other problems I need to work around?
Don't do it. You will just break the phone. Mechanically, but also in terms of its electronics.
- voltage has to be right, it won't work with 1.2 V. And your 1.2 V battery probably does not have exactly 1.2 V, so 3 batteries in series could give anything from ~4.5 V to ~3V.
- the battery has to be able to deliver enough peak current at a reasonable voltage. The built-in battery is designed for exactly this task, your other battery is not.
- the phone has a lot of electronics to monitor the battery to avoid damage to battery and phone. That electronics can give nonsense output if your battery is different in any aspect, with unclear consequences.
Likes Jeff Rosenbury
Not sure why you want to do this. Could you explain?
mfb is correct.
1. NiMH batteries and Li-ion batteries have completely different charge profiles, so the iphone charger will not properly charge the batteries. probably damage the phone.
(by iphone charger, I mean the battery controller in the phone, not the wall wart or USB supply)
2. NiMH is 1.2V, li-ion is 3.6
2. You will never get decent power density with NiMH compared to Li-ion.
3. Fitting 3 NiMH batteries into the iphone will be impossible.
4. Depending on your iphone model, the battery replacement is non trivial even with a proper Li-ion replacement battery.
Likes davenn
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
