Changing order of integration (double) in polar coord
  • Thread starter Thread starter nothingness00
    Integration Polar
3 replies · 2K views
nothingness00
Change the order of the limits of integration of the following double integral and evaluate.
[itex]\int_{0}^\frac{\pi}{2} \int_{0}^{cos(\theta)} cos(\theta)\,dr\,d\theta[/itex]
Evaluating as it is, I arrive an answer of [itex]\frac{\pi}{4}[/itex].
I know the region to be integrated is the semicircle bounded by the polar axis, with corner points at r = 0, and r = 1, with a height of 1/2. I know that normally, in the cartesian case, to change the order of integration requires the limits to be written from y(x) to x(y), with the x or y intervals adjust accordingly.
Thus, for this problem, the original region is bounded by:
[itex]0<r<cos(\theta)[/itex] and [itex]0<\theta<\frac{\pi}{2}[/itex].
Changing the form, I would write,
[itex]0<\theta<cos^{-1}(r)[/itex] and [itex]0<r<1[/itex]
Trying to evaluate in this manner, I end up at
[itex]\int_{0}^1 sin(cos^{-1}(r))\,dr[/itex],
after which I cannot go further. I have very little experience of changing limit orders in the polar case. Any hints would be appreciated!
Cool, thanks; Using the hint: I get
## \int_{0}^1 \sqrt{1-cos(r)}\,dr ##
Multiplying by a factor of sin(r)/sin(r), I get,
## \int_{0}^1 \frac{sin(r)}{\sqrt{1+cos(r)}}\,dr ##.
I use a substitution of
## u = 1 + cos(r) ## with
## \,du = -sin(r)\,dr ##.
I substitute the limits by using
## u_0 = 1+cos(0) = 2 ##
## u_1 = 1+cos(1) = ~1.5403... ##
Evaluating the new integral, through
## -[2u^{\frac{1}{2}}] ##
between u1=1.5403... and u0 = 2, I get an answer of ~0.173144 which is not quite ##\frac{\pi}{4} ##
Are my limits wrong, or did I blunder somewhere else?
Unfortunately the first line is still incorrect.
CompuChip said:
Hint: note that sin x = sqrt ( 1 - cos^2 x ).
What would x be, looking at your integrand (it's not just r, as you seem to have assumed!).
