Changing the Direction of Work
  • Thread starter Thread starter logan3
    Direction Work
Lifting a mass creates positive work as energy is expended to raise it. When lowering the object, the work done by the hand is considered negative because the force exerted is in the opposite direction of the displacement. This is due to the vector dot product, which results in a negative value when the force and displacement vectors are in opposing directions. Therefore, the work done while lowering the object is indeed negative. Understanding these concepts is crucial in physics when analyzing work and energy.
logan3
If I lift a mass up a certain distance and it creates a positive work quantity, then when I lower the object back down does the work become negative?
Thank-you
Yes, the work done by your hand on the block as you support it while lowering it is a negative quantity.
(The vector dot product of a force in one direction and a displacement in the opposite direction is negative)
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
