A Can Time Scale Change Analogously to Spatial Expansion?
  • A
  • Thread starter Thread starter TheCanadian
    Time
The discussion explores the concept of whether time can scale analogously to spatial expansion, a topic that remains largely theoretical and not well understood. The metric expansion of space has been observed, but its origins are unclear, leading to questions about the possibility of intrinsic changes in the temporal domain. The idea of time scaling in flat space is considered, but it faces challenges such as a lack of proposed mechanisms and potential violations of special relativity. The conversation highlights the difficulty in testing such phenomena, as experiments cannot currently measure the same point in space at different times. Overall, the relationship between spatial and temporal dimensions remains a complex and unresolved area of study.
TheCanadian
I feel like this concept itself is a bit out there, but thought I'd try to find more information on it (and why perhaps none of it makes sense).
I've been studying the metric expansion of space in my courses and been really interested by it (as most here are). As far as I can tell, we do not quite understand the origins for this expansion; we have simply observed evidence for it. Now it's likely been discussed and dismissed in the past, but I couldn't find any pertinent answers for my ensuing question—or maybe I just didn't understand my lessons on relativity well enough. In any case, I was just wondering if an analogous phenomenon (intrinsic scale changing) occurs in the temporal domain? Assuming isotropy as in the case of spatial expansion, is having the scale of time changing in flat space possible or even testable?
I realize we make time the dependent variable for a lot of models simply because it's most helpful for us in terms of testing and personally understanding the models. And I realize symmetry isn't necessarily necessary, but assuming such a change in time is possible, I can't help but wonder (e.g. perhaps the FLRW metric has a corresponding ##a(x)## term for the ## -c^2dt^2## term).
To my knowledge, the answer to all of the above is no as we don't have any proposed mechanism for this to even take place, and are not able to experiment at the same point in space at two separate times (yet, hopefully). It also seems to violate special relativity. I realize I haven't formulated much except a very broad question, but is there much discussion on the above that you could refer me to? I've been reading up on the differences and similarities between the spatial and temporal dimensions. Although why we have expansion (or contraction) in one and nothing in the other is still puzzling to me.
Space news on Phys.org
Having nothing in front of the dt^2 in the metric is a coordinate convention. You could perfectly well write down coordinates where this is not the case, but they would likely be less useful.
However, writing an arbitrary function of x is generally not going to match observations.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
