Characteristic Subgroup is Normal
e(ho0n3
Recall that a subgroup N of a group G is called characteristic if f(N) = N for all automorphisms f of G. If N is a characteristic subgroup of G, show that N is a normal subgroup of G.
The attempt at a solution
I must show that if g is in G, then gN = Ng. Let n be in N. Since N is characteristic, there are automorphisms f and f' of G and elements a and a' of G such that n = f(a) = f'(a'). There are also elements b and b' in G such that g = f(b) = f'(b') so that gn = f(b)f(a) = f(ba) = f'(b')f(a) = f(b)f'(a') = f'(b')f'(a') = f'(b'a'). This is all I can think of and I don't see how this allows me to prove that N is normal. Am I missing something?
A subgroup is normal if and only if it is fixed (set wise) under conjugation by any element. That's precisely what gN=Ng (i.e gNg^-1 = N) says
Wouldn't it be nice if f_g:G-->G: h-->ghg^-1 were an automorphism of G for each g in G?
Thanks for the tip quasar987. I understand now.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
