Charge electric car from dryer plug?
MTurner
Hello, I was surprised to read today that one of the bigger impediments to electric cars coming to market is the fact that the 'quick' chargers require installation of a separate power line. Why? Every house, apartment, condo, etc in America pretty much has a 220 plug for the dryer. Why can't those be used to quick charge electric cars? It's not like people are using their dryers 24/7. I asked around a bit and basically the main reason a separate line has to be run is because of the danger of 220, but I don't see electric cars becoming commercially viable if everyone knows they have to get a separate line run at their own expense, and repeat it every time they move. Also, what about all the people in apartments, condos, etc? Is there not some type of system that could be devised that could securely fasten to the 220 plug with pass-through for the dryer, and run a cable up to 70 ft for hookup to a vehicle? It just doesn't seem like that would be something that is too hard for us to make...any ideas?
I saw the article and ran the math and I was pretty confused by the issue too. Here's what the CNN story says:
Electric cars like the Nissan Leaf and Chevrolet Volt ideally use special "quick chargers" that have to be hardwired directly into high-power lines.
Installing the chargers is not like putting in a ceiling fan. The equipment has to be fully approved, installed by a competent professional, and in most cases, a city or state inspector will have to approve it all.
You could plug your car into an ordinary wall socket, but not if you're in a hurry. Charging a Nissan Leaf would take up to 16 hours, and charging a Volt would take eight.
http://money.cnn.com/2009/12/11/autos/electric_car_charging_challenges/index.htm?cnn=yes
So let's look at the math:
The Wiki in the Volt has a 16 kWh battery, with 8 kWh useable (it is a plugin hybrid.
The Wiki on the Leaf just says a 24 kWh battery.
The Wiki on the Mini-e says a 35 kWh battery.
The National Electric Code says a branch circuit can't be designed more than 80% full, which for a typical residential circuit is 120Vx16A=1920W. I'm not sure if that is a the real maximum for a single device on a multiple outlet circuit, though, since the biggest draws you ever see for household devices are 1500W. But let's go with it...
For the Volt, that means the 8 kWh capacity takes 8/1.92=4.17 hours assuming 100% charging efficiency.
For the Leaf, 24/1.92= 12.5 hr
For the Mini-E, 35/1.92 = 18.2 hr
Now the Mini-E and Leaf have 100+mile ranges, so they go beyond what a "commuter car" should be expected to do. But yeah, if you want to drive 80 miles each way to Grandma's house for Thanksgiving, you may have an issue. As a 40 mile a day commuter car, it wouldn't be an issue.
Now let's say you use a dedicated 40A, 220V circuit (actual draw, 32A, 7.04 kW). The new numbers are:
Volt: 8/7.04=1.1 hr
Leaf: 24/7.04=3.4 hr
Mini-e: 35/7.04=5.0 hr
The downside, of course, to these is that you do need somewhat special circuits, so your options for where to charge would be limited.
Now what about the phrase: "hardwired directly into high-power lines"? The words don't really have a lot of meaning to me. "Hardwired" may mean there is no plug, that you wire the charging device directly to the circuit. That's not necessary and not how I would design it, but it may actually be that way. "High-power lines" is a completely meaningless phrase. I don't know what they intended by it, but every normal residence in the US has 220V.
A bigger issue, not discussed, is that not all residences will have that much extra power available. It isn't uncommon for a single family house with electric hot water, dryer and cooking (plus an air conditioner...) to have a 100A service. That's 4 devices up to 32 A apiece. You can use some diversity and not assume they are all running at full capacity all the time, but still, there may not be any extra capacity on such a house to add another 220V/40A circuit. And upgrading your service is very expensive.
In any case, though, yes you do need an electrician to add a 220V/40A circuit (almost certainly not an inspector). If the wiring is easy, it should cost <$500.
Thanks for the math on that. I'm assuming those timeframes are to take a vehicle from 0-100% charge with a dedicated line. The question, however, was whether it would be feasible to simply use the 220 plug almost all housing units have available to charge an electric vehicle. Yes, you won't get the same timeframes as you would from a dedicated circuit, but most homes are not running at the capacity of their circuit a majority of the time. Most people just need a simple easy way to plug their cars in overnight for the next days commute, or to go back out that evening. So why not make it as simple and easy as using the dryer plug when circuit capacity is available (when ac is off etc)? Is there any reason NOT to? Does the current cause too much heat meaning special heat shielded cables are needed (if so, why don't dryers have them)? Can it not be transmitted across 70 ft easily? What are the logistical reasons it can't be done?
Except that you might need a really long cable to go from your dryer to the garage, no, there shouldn't be any problems with that.
Yes it's perfectly reasonable to charge a small plugin electric from a 220v/16A dryer outlet (in the US) or a normal 230V/13A outlet (in the Eu). in Europe you could also run a separate 32A or 50A 230V circuit as you would for an immersion heater or electric shower. As russ worked out.
You would want slightly heavier cable than a regular extension cord just because of the handling it will take, being dragged out to the car every day, stepped on and driven over. You might also want to wire it into the dryer supply rather than use a regular dryer plug, but that's easy enough.
The demand for fast charge is for commercial operations. If you don't have a garage near the house you might want to charge up like you would at a gas station. Since even with custom power supplies it's going to take 15-30min to recharge just because of the limits of battery technology. The guess is that places like parking garages will offer pay-for recharge while you park, or supermarkets/malls will offer free recharge while you are shopping as a draw.
I think it's just a matter of safety. They are pretty high currents.
I think that's the concern - too easy. Expect to read about some fool who buys a $0.99 cheap extension cord at the discount store & then grafts on the plug & socket from an old dryer cord... When the wires melt and his house burns down he's going to sue Chevvy
Seems like dragging a 70 foot cord up from the basement to the driveway every nite is kind of an inconvenience. I would sure rather have a dedicated line, with a self-winding retractable feature. Take a look at the kind of "shore power" cables that boats use to hook up power at marinas. Heavy cables prevent overheating & unnecessary voltage drop.
if you consider that you will be trying to charge your car after work, and your wife will be trying to get laundry done after work (our fam of 5 meant laundry every nite) then the shared plug gets "busy". during the 8 summer months in the south the AC unit will be running all day long, then with the dryer, hot water heater, home accessories, and electric car, I would bet that the 80% rule would get very close to the total load the house can safely handle. now add all the houses in the subdi-land, and added grid draw is going to go up. maybe what they really ment was the grid would need upgraded.
and I an not sure which I rather have, a way to work, or a clean shirt when I get there
dr
Actually, electric dryers tend to run on 40A circuits, not 20A circuits and nominal in the US is 240V, not 220. Here's a pretty standard electric dryer that's 240V, 26A: If the entire world's population were infected
The cable would be nowhere close to a regular extension cord. Neither the wire size nor the receptacle configuration would be typical.
russ_watters said:
I saw the article and ran the math and I was pretty confused by the issue too. Here's what the CNN story says: http://money.cnn.com/2009/12/11/autos/electric_car_charging_challenges/index.htm?cnn=yes
Volt: 8/7.04=1.1 hr
Great post Russ.
Yes I believe that's a crudely put way (by Money) of saying the quick chargers are probably 440V, i.e. service not typically available in residences.
A very good point. Not only is the upgrade to a large service expensive, the power utilities would push back if it was requested on a large scale. If 6/10 residences in a neighbourhood all wanted to bump from 100A to 400A, and use it, they'd have to upgrade the local transformers, at least. Essentially the residential neighbourhood would start looking like a commercial/industrial load to them, which is fine, but I expect they'd want to charge accordingly to handle the distribution upgrade.
gmax137 said:
...I would sure rather have a dedicated line, with a self-winding retractable feature. .
I believe that self-wind is an important oversight now in most of the curb side, on the street chargers being installed. None of them have/support such a feature. The car driver rolls around with the cable, pulls it out to plug in. No retraction means at large scales means either a) cables have to be annoying short for street side parking maneuvers, or b) we all trip and drive over the slack in long cables.
Edit: looks like coiled cable is the proposed answer.
Couple examples:
Those look a bit 'design concept'
There is already a couple of proposed standards, Europe and Japan look like they are all going to agree on the Merc system.
The US could go with a different plug because people don't often drive into America from another country (except Canada which doesn't count ;-)
thanks for the photos, mheslep
I don't see why the concept has the cable provided by the driver... I can see people unplugging the car end, go inside to pay or get a coke, and drive off leaving the cable behind. If I pulled into a gas station and found a just a hose fitting on the pump, I'd be pretty surprised ('what do you mean, you didn' bring your hose...'
I suppose there's a simple explanation that makes sense
Okay, we have to be careful here. There seems to be some confusion:
- Quick chargers mentioned by the article are 440V and up to 50 kW. No one is going to be installing those in personal residences. At first, there will be maybe 50 of those per state installed in major cities and on major freeways (e.g. between Los Angeles and San Francisco).
- Home chargers installed for owners of Leaf and Mini will be substantially less powerful, they will draw 10 kW tops, possibly much less.
- You don't need to run a separate circuit, you may be able charge from the dryer outlet. You do need a basic piece of hardware that plugs into the dryer outlet and a proprietary cable (SAE J1772) that runs from that hardware to the EV. That way your EV would be able to negotiate the current without burning out or blowing the fuses. The connector cable is designed with a number of safety features. For example, it is automatically depowered if it's not plugged in, or it's damaged (maybe because you ran it over while backing out of the garage the previous night).
50 KW (actually KVA) transformers with single phase 240 volts is not at all uncommon in rural areas. If someone has the need and is willing to buy that amount of power, the supplier will see to it that the equipment is put in place to do so.
Also, the power company is required by law to provide you with a service to your house that meets any reasonable request. What is "reasonable" is defined by the law. So if a 400A service doesn't currently fit the definition, the law could always be changed to occommodate this.
I would also like to point out that what is "reasonable" as defined by the law will likely vary from location to location. I don't doubt one bit that there are locations where a single phase 240 volt 50 KVA transformer at a residence would be above and beyond "reasonable".
400A is common, I have it.
hamster143 said:
... At first, there will be maybe 50 of those per state installed in major cities and on major freeways (e.g. between Los Angeles and San Francisco).
50 quick charge stations per state? I doubt it. Maybe in California. Look at the details: A Leaf quick charge is supposedly 80% of ~25kWh (100miles) in 30 mins, i.e. ~40 kW per charger. Half an hour wait means a rest station has to be built or collocated - bathrooms, food. Then nobody will tolerate waiting in line for a charge at a "quick charge" station, so 5-10 chargers have to be installed. Parking, etc. If the batteries improve in charge rate - to say 10 minutes ( LiFePO technology doesn't support this yet), then we have a 150kW charger required, per vehicle charge point. Further into the future, with say 200 mi/ 50kWh, 5 minute charge batteries, the service is 600kW per charge point!
What's needed is some kind fast battery exchange mechanism. There's a Berkely study showing wide spread acceptance of EVs in 10 years IF battery lease and exchange can be made to work, twice that time if not.
I am wondering who is going to pay for all the "charging pods" and who will stand good for the power bill. also, those connectors and cable don't look like they'd be any fun in parts of the world that have harsh winter conditions. Ice and snow packed into the connector on your car, then some "brainiak" gets out his truck key to dig ice out of the end and (insert the smell of bacon here)
people are scarey enough with gasoline
I say a lady "pressure wash" her trunk lid with about a gallon trying to muscle the hose to the wrong side of her car.
a "full service" fueling infrastructure would be much better (for in town) as it would control access and help with a minimum level of safety
dr
Same type of people who build and pay for all those gas stations: businesses. The bill is paid immediately when one charges (card swipe, or smart charger knows the smart car).
a "full service" fueling infrastructure would be much better (for in town) as it would control access and help with a minimum level of safety...
I expect the underlying theme of a thousand like minded posts is a powerful reluctance to give up that "I have made fire" feeling that goes with riding around on top a combustion engine. It's been that way for a 100 years, and it is not to be lightly. Possibly what's needed is a series of demonstrations where a large vehicle battery is catastrophically destroyed in a way that intentionally causes a large fireball, or even some Nikola Tesla like showmanship that adds substantial arcing. Think that will scare people off? Not a chance, with Hollywood exploding ten cars per second. Instead, a dramatic battery explosion will bring them (men anyway) on-board immediately.
On a rewatch of The Matrix the other night, it occurred to me Hollywood had exactly the same problem with vehicles of that dark and pessimistic future. Morpheus's ship could not simply be allowed to quietly electro-glide along, even though stealth was clearly a life and death requirement throughout the plot. They had to add in all those over the top arc effects to show off some Real Power (tm).
I am not being dismissing. The change can be good. But from a reality sort of sense, the logistics are going to be significant. In the current economic climate, how many business are going to borrow millions of dollars to put in service pods. gas stations do not make their money in fuel, its the beer cigs and chips. a card swipe pod on the street in town will have to make all the profit, loan interest, and principle back from what they "over charge" (sorry...pun) above the residential rates. I personally do NOT want my tax money spent on this, either.
dr
I think you're oversimplifying things. There's lots of gas stations around here that sell nothing but gas. And guess what, they're the cheapest ... There may be a chicken - egg thing (between the cars and the charging stations), but once there is demand for a service (battery charging) there WILL be businesses that will provide it.
Has anyone said anything about the gov't using tax money for any of this infrastructure?
Quite a few.
http://www.coulombtech.com/press_releases/release_20091214.php"
http://www.coulombtech.com/press_releases/release_20091207.php"
http://dealbook.blogs.nytimes.com/2009/12/02/in-denmark-ambitious-plan-for-electric-cars/"
http://www.cnet.com.au/q-a-better-place-s-electric-car-plans-brilliant-or-nuts-339296126.htm"
http://news.cnet.com/8301-17912_3-10220414-72.html?part=rss&subj=news&tag=2547-1_3-0-20"
Edit: Besides, this was all done once before. 1910 in the US saw charge spots all over the major cities. Hotels, etc. The cost of slow charge infrastructure, frankly, is trivial. Most of it is already in place in 2009, except for the last 10 feet. The financial hang up is in the batteries.
Exactly right. That's why they won't care whether they sell fuel, batteries, or electricity.
The same is true for the service connection to your residence. Appears street side, mass roll out charge spots cost ~$400-500 ea, installed.
dr
I don't want any more of my tax money spent on EVs than already is spent on subsidies for oil and gas.
With a 20-30min charging time and less infrastructure (no tanks or deliveries) the suggestion is that malls, supermakets and parking garages would offer charging to attract you to their store rather than the competitor. And since the cost of a charge is less than a parking mater in most cities they would probably include it free with some level of purchase.
If you proposed a gasoline engine today it would be laughed out of court.
You want people to carry around 10-15Gal of explosive fuel, inside a car and burn it in a hot engine !
mgb_phys said:
... they would probably include it free with some level of purchase.
Wishful thinking? Actually you probably know there's no such thing as 'free.' If the stores do include it 'no charge' (hahaha) they will just raise the prices on all their goods. After all, there's no reason to expect retailers to pick up the national burden for transportation energy cost...
Cost structure is an interesting issue. My electricity is up to about $.15/kwh now. But a large commercial user tends to pay around $.06-$.08. So They could charge you a healthy mark-up and it would still be cheaper than buying the power at home!
That can be a difference between you place and my place (I am in EU, more precisely in PL but I doubt it matters). To my left I have an electric heater 2 kW, in my kitchen I have 1800 W electric kettle, heater in my laundry machine is 2 kW (or at least it was 2 kW in the previous one, not sure about the one we bough this year). Hair dryers 2 kW are not uncommon. For many years I thought 2 kW is the limit, few years ago - after the plug has been fried - I was surprised to find out that heater in our dishwasher is actually a 3 kW unit. So much more than 1500 W you listed.
And I am talking specifically about 240V one phase devices, water heater in my bath is 18 kW, but it uses three phases supply, so it is in different category.
Not that it changes much in your calculation and conclusions.
The retailers also light and heat (or air-condition) their stores 'for free'
Parking costs $1-5/hour in most cities but stores offer free parking which is losing them $1-5/customer.
Would you go to a mall that charged you for parking meters, if you did would you hurry out as quickly as possible rather than browse and buy.
A 25Kwh charge is costing them something around $1 at commercial power rates.
If you had an electric car and a certain store offered free 30min top-ups you are going to go there rather than the discount store?
And since its going to take 30mins to charge you are going to stay longer and buy a few $5 coffees
So double whipped no-foam espresso mocha lattes are going to pay for the nation's transport!
Laundry machines don't run on standard circuits in the US. The standard power outlet is 120V/20A. Washers and dryers run at 240V and whatever amperage they need in dedicated circuits.
All of those other devices you listed (portable electric heater, coffee machine, hairdryer - microwave too) tend to run at exactly 1500w and I've never seen one above it.
Yes, those also run on special/dedicated circuits in the US, though at 240V, 1ph. In the US, residences don't get 3ph, they get two 180degree opposed 120v legs for 240 between them. I like the flexibility of it.
  • Featured
  • · Replies 73 ·
  • · Replies 19 ·
10K
