Charge in Metals (Supposed to be easy)
  • Thread starter Thread starter alfredo24pr
    Charge Metals
The discussion revolves around determining the initial charge on metal ball K after a series of interactions with balls J, L, and M. Initially, ball J has a charge of 0e, L has +42e, and M has -48e. After touching K, L, and M sequentially, the final charge on J is calculated to be -6e. The calculations indicate that the initial charge on ball K must be -48e, highlighting the importance of correctly applying the principles of charge distribution during the interactions. The conversation also addresses a mistake in the calculations, emphasizing the need for accuracy in the steps taken to reach the final answer.
alfredo24pr
There are 4 identical metal balls: J, K, L, M. Initially, J has charge QJi = 0e, L has charge QLi = +42e, and M has charge QMi = -48e. The ball J touches the ball K, and they separate. Then, the ball J touches the ball L, and they separate. Then, the ball J touches the ball M, and they separate. The final charge on the ball J is QJf = -6e. What was the initial charge on ball K ? QKi = ? (You must put a + or - sign on your answer, unless you get zero; for example +5e if positive, -10e if negative, 0e if zero.)
When two conductors touch, they become effectively one single conductor with a net charge equal to the sum of the net charges of the two individual conductors. If two conductors with identical geometry are touching, and then they separate, each conductor takes one-half of the net charge that was on the pair.
K=x, so I begin
(x+0)/2 = J after hitting K and then separating
[(x/2)+42]/2 = x+84= J after hitting L and the separating
[x+84+(-48)]/2 = (x+36)/2
The final charge is -6e, so
(x+36)/2=-6
x+36=-12
x=-48e
K=x, so I begin
(x+36)/2=-6
x+36=-12
x=-48e
This line of your working
Is incorrect. both denominators of 2 have disappeared - it is if you have suddenly decided to multiply by 4 ?
Assume j,k,l,m = 0,-48,42,-48 initially. Then j+k gives j = -24, then j+l gives j=9, then j+m gives j = -39/2?
Did I make a mistake or did you? %^/
You did: other wise you would have got the requisite -6 for the final answer instead of -39/2
